AMS is traditionally close to the silver star. If there is anything to this rumor a protest would be a good idea. The rules forbid that Hp gains are made and it is the teams obligation to stay inside the rules. If Ferrari have cheated it can be easily found. The FIA can always make a bench test with the two different versions by an independant lab.Rumours of a performance gain under reliability guise
It is common knowledge that, not only are the Maranello based team's drivers getting the best starts off the grid, the V8 power plant in the back of the F2008 is now perhaps the most powerful in the entire field.
Last year, however, the engine situation between teams seemed closer, leading to suggestions that Ferrari's permitted tweaks for 2008 have added tangible performance to the unit.
The German magazine Auto Motor und Sport estimates Ferrari's horse power gain compared to last year at 'within the two-digit range'.
Most engine manufacturers made permitted tweaks to their V8 designs over the winter, but it is rumoured that some rival teams are unhappy that Ferrari's changes - apparently green-lighted by the FIA - seem to have resulted in a significant performance gain.
Auto Motor und Sport said Ferrari's rivals are concerned that the Italian team's 2008 changes were submitted "under the pretext of reliability problems".
"The (engine freeze) rules do not allow any great leaps. So whether a development has taken place to increase performance, I cannot judge," BMW motor sport director Mario Theissen said at Istanbul Park.
"But I assume the normal procedures have taken place. I have no suspicions," he added.
There could be other explanations for the quick starts. Ferrari have changed their rear suspension significantly as scarbs has reported in his season opening report. are they just getting more traction out of their suspension and engine map than others? they have significant know how with Bridgestone tyres and perhaps they have found a tweak that other teams havn't.
Luca Marmorini has hinted at other legal ways to gain an advantage. If you improve fuel efficiency you can gain significant weight advantages. so performance can come from legal engine developments and aero efficiency gains and translate into significantly less fuel weight compared with less efficient cars. the report talks about changes to the pistons. that could hint at a different more efficient combustion process in combination with different injection.
