The need for reduction of first corner start crashes
johnny comelately
johnny comelately
110
First corners after the start where accidents that take out competitors through no fault of their own can needlessly ruin a race result or more critically championship chances.
It is true that driver error is one of the main causes, but because it happens continually, that probably wont change.
So, what external things can be done?
Some solutions may be redesigning those first corners, Shanghai seems to be a reasonable concept.
Or more distance between rows, making qualifying more important;
Rolling starts, seems fantastic at Indy etc
Maybe the vote should be with those who pay for the repairs
marvin78
marvin78
Re: The need for reduction of first corner start crashes
I think, we don't have to take everything away that makes the races and the championship more interesting. This belongs to racing. I don't see the point.
Another "let's change F1 for no real reason" thread.
Standing starts and the mayhem that can ensue are part of F1. We certainly don't need to go down the rolling start route preferred by Indy. Anyway, look at the start at St Petersburg this weekend. Will Power still managed to get in to the wall in the first couple of corners even with a rolling start.
No, we don't need to change the start procedure or the first corner.
TAG
Why do we have to do anything?
Singapore last year what would you do? If a driver is idiotic enough to keep making the same mistakes over and over, there's already a system in place to punish that and even ban them from the next race.
If it aint broke don't fix it, like the qualifying change fiasco. I think you need to state a much stronger case than affecting championship races, like Singapore.
माकडाच्या हाती कोलीत
Maritimer
Maritimer
19
If passing was easier the first corner would be less of an issue. Dependence on wings is the issue imo, slap a venturi floor on the cars and they could make passes when its opportune instead of asap at the start of the race.
zac510
zac510
22
My memory is possibly a bit selective or flaky but I think there are far fewer first corner/first lap/restart crashes than there were 20 years ago. However I've never seen this quoted as a statistic.
Anyway in terms of a race, there is no difference between a crash on the first lap and a crash on lap 23 if your concern is that retirements are affecting the championship, or someone's race by no fault of their own. Ergo, if you want to remove crashes on lap1 then you want to remove crashes on ALL laps. Let's face it, a race with no crashes or retirements would be pretty boring. A footballer's fumble, or a cricketer's dropped catch every now and again keeps the game exciting.
marvin78
marvin78
Get rid of the drivers and let computers drive the cars. Or better: only simulate the races and nothing get's damaged. :wtf:
johnny comelately
johnny comelately
110
Maritimer wrote:
13 Mar 2018, 16:25
Yes, passing is a major problem and its a fair statement how it affects the first corner desperates.
Most problems are linked, but I believe the funnelling and subsequent crashes need addressing as well.
The implementation of solutions for better passing still seem a long way off though.
zac510
zac510
22
In statistical terms that's why we have more than one race in a season, so that one or two first corner incidents in a season is less likely to ruin a driver's chance at winning the championship than if there were, say, 3 races in a championship.
Sieper
73
Well, because overtaking has become much more difficult with the current high drag (wake) cars we will only see more attacks in the first corners, If it doesn’t happen there chances are it wont at all.
dans79
267
zac510 wrote:
13 Mar 2018, 16:58
You only have 3 PUs though, so you can get hosed through no fault of your own, simply because someone ran into you and damaged your PU. I don't think the rules have anything about free PU components that are damaged in accidents do they?
206 177 106 104 9 9 7
Sieper
73
That could damage a gearbox but a PU? Very unlikely, Yes the cooling system will get easily damaged but then again, you will be stopped, or stop yourself If the temperatures run up.
dans79
267
Sieper wrote:
13 Mar 2018, 17:31
watch Hamilton go right up the back of Grosjean.
Here's the answer:
No danger of coming together, wings and PUs kept safe. The FIA absolutely must have guide tracks added to every circuit immediately! =D>
#-o
Someone's got no sense of humour... :roll:
