Burning lean: Pre-chamber combustion tech
blueytoo
blueytoo
Re: Burning lean: Pre-chamber combustion tech
godlameroso wrote:
29 Mar 2018, 03:18
There's really only one way to do it with one injector and one spark plug, and the side injector is the big hint.
if such a thing exists, there must be a patent out there. the variable pattern injectors i can find are still symmetrical and omnidirectional.
seems a lot easier to put the injector on the boundary of the prechamber and main chamber.
blueytoo
blueytoo
recent patent permits one injector in main chamber. prechamber ingests mixture in compression, assisted by richer mixture near prechamber apertures.
http://www.freepatentsonline.com/y2017/0096932.html
johnny comelately
johnny comelately
110
Could posters say what they think the overall (if the chamber is not homogenised) lambda is for steady state and transition please:
johnny comelately wrote:
29 Mar 2018, 13:39
The only ones that know are the ones tuning the fuel tables.
johnny comelately
johnny comelately
110
godlameroso wrote:
29 Mar 2018, 20:47
29 Mar 2018, 13:39
OK yes, but what do you think it is?
650
1.5 - with conventional valve working and conventional VE
though VE restriction via unconventional IV period could give near 1 lambda with the apparent 4 bar absolute 'boost'
Muniix
Muniix
29 Mar 2018, 23:34
godlameroso wrote:
29 Mar 2018, 20:47
29 Mar 2018, 13:39
I'd guess 1.6 - 1.85. Maximum Thermal efficiency would be closer to 1.8, the high boost pressure above 3.5 bar in small 266cc cylinders and the bore to stroke ratio giving it high peak pressure to mean, high BSR reduces this.
The side mount injection would be chosen for turbulence enhancement possible for non premixed secondary injection after TDC.
What about injector flow per pulse? Surely it's spraying more than once or twice per engine cycle. They must have had lots of issues with injector dribbling at first. Maintaining accurate spray and droplet size becomes challenging at the time scales involved, even with piezoelectric control. Particularly(pun intended)with a 500 bar pressure limit.
There's a lot of development just engineering better injectors, I'd say 30% of current power gains have come just from the injectors, and the fuel system in general. Ironic then that in cost conscious F1 this area is pretty much a bottomless money pit, add to the fact that this is not an area that incurs grid penalties so the manufacturers are free to upgrade this system throughout the season.
