On which side is downforce more effective?
Is downforce more important on the loaded or unloaded side of a car during transient maneuvers? Say in turn 8 around Shanghai, the long mid speed right hand, would you gain more in the corner by having more downforce on the right side or left side of the car?
Tim.Wright
330
Re: On which side is downforce more effective?
From a grip perspective you will benefit more from loading more lightly loaded wheels which will usually be the inner wheels. Tyres have a coefficient of friction which drops as you increase their vertical load.
From a balance perspective it's difficult to generalise. A laterally offset downforce will cause a lateral load transfer which causes symmetrical effects like toe and camber to create net lateral force which could change the balance.
Additionally you should consider that if the downforce can be asymmetrical (which I'm sure it is) then so is the drag. A lateral drag offset will cause an US/OS yaw moment depending on which side it acts.
I could imagine an ideal situation would be to create downforce on the inner wheels and drag towards the outer wheels to in function of the sideslip angle. Difficult to imagine how to implement this though.
bill shoe
151
I think a given amount of downforce would be more effective on the inside (lightly loaded) side of the car, because tire lateral force (normalized to vertical force) declines at higher loadings. Also would heat and wear the tires more evenly.
Edit: a.k.a. what Tim said.
Contact:
Outboard car side in corner is closer to the ground, no matter how stiff the suspension is - tyres flex. Being closer to it makes more downforce on that side and it would be great to have it evenly distributed or even more on the inner side of the car. That's why active suspension and all those recently banned "trick" suspension set-ups are/were worth investing into. :)
#Aerogimli
JonoNic
Well negative camber allows the outside wheels to run square during hard cornering. So aero on the outside would do the same?
Sent from my SM-A520F using Tapatalk
Jolle
132
Extra load, trough balance, active suspension or downforce (any other then mass) is always best welcomed at the wheel that will loose grip the earliest, so, the outside wheels. Outside front for turn in, both outside wheels mid corner and rear outward wheel corner exit.
Tim.Wright
330
Jolle wrote:
15 Apr 2018, 22:38
In my experience, looking at both wheel force sensors on actual cars and simulated forces in mathematical models, the inside wheels drop off their cornering force well before the outside. They are essentially sacrificed on purpose using load transfer and geometric effects to ensure that the outer wheels (which produce the dominant cornering forces) produce grip as long as possible.
I've always wondered how a assymetrical Indycar would perform (setup is already assymetrical).
Scootin159
Indy cars already run asymmetric aero on some ovals. In particular in Indy 500 qualifying, it's not unusual to see them have more wing on the inside of the car than the outside. Further evidence that having extra downforce on the inside (as well as a slight drag force rotating the car) would be better than the inverse.
trinidefender
317
Vanja #66 wrote:
15 Apr 2018, 22:30
In all practical applications to do with F1 then yes but just to be a smartass :D I'll remind you that if you have your roll centre above your centre of gravity then your car will actually roll toward the inside of the corner.
Contact:
trinidefender wrote:
16 Apr 2018, 05:09
Cheers to that! :D
But as Tim said, in practical applications the outside front wheel is always more loaded, so there's no denying how cars roll in reality. :) Formula Student cars in general have pro Ackermann steering, but only because of very low cornering speeds and low vertical loads as far as I know.
#Aerogimli
Andres125sx
Tim.Wright wrote:
14 Apr 2018, 22:08
Is this correct Tim? I know you know what you´re talking about, but this makes no sense to me so I have to ask just in case it was a mistake while typing. If it´s not a mistake and that´s correct, may you elaborate?
Maybe that´s only on a perfectly flat surface? Tarmac is far from flat so in my mind when a tire load is increased, rubber should get into the holes deeper, increasing friction
617
(1) if the coefficient of friction doesn't vary with vertical load the friction (force) is proportionate to vertical load increase
(2) if the coeff of friction falls with load increase but in a smaller proportion the friction force has still increased with load
but the increase in friction is less than case (1)
ie the tyre is less 'efficient' at high loads
I thought
Tim.Wright
330
It's basically what Tommy said. The frictional force increases yes but the coefficient of friction decreases (they are two different things)
The coefficient of friction is the instantaneous slope of the available friction force when plotted against the vertical force. The frictional forces increase regressively with vertical load. It's roughly an inverse parabola. Theoretically there will exist a force at which increasing the vertical won't give you anymore grip force.
dren
226
Wouldn't your tire contact patch increase with vertical loading since the tire is flexible?
Honda!
