Reverse gear, or MGU-K?
Brake Horse Power
Brake Horse Power
Hi,
I was watching the Baku race with some friends, and one of the drivers needed to put the car in reverse gear.
Actually one of my friends didn't even know f1 cars even had a reverse. The other one said they don't have a reverse but probably an extra electric motor. He doesn't have a clue what he is talking about but it was actually an interesting point; all f1 cars have a mechanical reverse gear right? Why don't they use the MGU-K as reverse? Is it a packaging issue? You would need to attach the MGU-K to an auxiliary input shaft of the gearbox, with a clutch seperate from the ICE. Obviously you cant turn the ICE the other way around. This way you can reverse quicker (not needed often), save a reverse gear (weight) and maybe it can do some magic with a launch control since the clutch can be engaged at the start and the MGU-K can immediately start spinning..
roon
roon
449
Re: Reverse gear, or MGU-K?
Sounds heavier than integrated reverse gears. Electric drive in pits might be useful.
Jolle
Jolle
180
or, just a very small E motor on the differential with a retractable gear like a starter motor. Would only have to be one or two hp.
an extra clutch on the K unit would cost power.
AJI
AJI
38
roon wrote:
Tue May 01, 2018 9:58 pm
....Electric drive in pits might be useful.
Ive been expecting this one for a while now, but only if they reintroduce refuelling.
Honestly, if they're so concerned about safety, slowing down pit stops makes sense. When you consider the only injury this year has been a mechanic and the only other 'unsafe' non racing related incidents have been wheel nuts...
Sorry, off-topic.
As to reversing with the K. If there was one on the front wheels, sure!
roon
roon
449
AJI wrote:
Tue May 01, 2018 10:17 pm
Sorry, off-topic.
If they go front-axle KERS maybe they'll drop rear-axle reverse drive. I wonder what recent LMP1 did in this regard.
AJI
AJI
38
roon wrote:
Tue May 01, 2018 10:19 pm
It makes total sense to delete the reverse gear if you have a front K.
Brake Horse Power
Brake Horse Power
Thanks guys, difficult for me to assess if there is any weight to be gained. I don't know how complex or heavy the reverse gear is or how the mgu-k is exactly mounted.
What would you want to use the mgu-k in the pit for? Isn't it a disadvantage to drain the battery a bit? Actually they should be able to charge the battery through MGU-H and K while driving through the pit lane. Are they doing this already?
Jolle
Jolle
180
Brake Horse Power wrote:
Sat May 05, 2018 6:18 pm
The reverse gear is very light and a part that isn't been developed in years (if not decades) so no additional costs.
The MGU-K is directly geared to the crankshaft, so you can't run on E power alone, for that you need a electric motor after the clutch in the gearbox.
If E power or reverse gear will/would be electric only, they would need/use a second electric motor that could maintain the car at 100 km/h, so extra weight and more development.
ian_s
ian_s
the original rules for the turbo hybrids had electric only power in the pits, but it was dropped after some protests
