Renault Sport F1 R.S. 18
TalnoRacing
Re: Renault Sport F1 R.S. 18
ScrewCaptain27 wrote:
05 Apr 2018, 17:00
First shot of the new all-CF gearbox:
https://uploads.tapatalk-cdn.com/201804 ... 2fea92.jpg
Via AMuS
The surface finish of the gearbox does not look as smooth as body panels (and maybe it does not have to be as smooth). Do they laminate carbon onto a plug (which creates a smooth inside), or inside a mold (which should create a smooth outside)?
ScrewCaptain27
577
New FW with reprofiled main flaps:
Via @AlbertFabrega
- Serj Tankian
ScrewCaptain27
577
More images of the new wing by AMuS:
- Serj Tankian
ScrewCaptain27
577
New low-DF rear wing with all-new McLaren-style endplates:
Probably the skinniest RW so far.
Via @AlbertFabrega
- Serj Tankian
Flying JPS Lotus
37
26 Apr 2018, 21:51
https://uploads.tapatalk-cdn.com/201804 ... c0ca08.jpg
https://uploads.tapatalk-cdn.com/201804 ... cd277d.jpg
Via @AlbertFabrega
Probably convergent evolution more or less. Reminds me more of Toro Rosso's rear wing endplates.
"Looks like meat's back on the menu boys!"
#AeroUruk-Hai
Dazed1
Dazed1
When they do an adjustment to the front wing on a pit stop, do they have some sort of programmed screw driver to turn a screw X number of turns? Three seconds for an adjustment just seems iffy.
Zynerji
112
Flying JPS Lotus wrote:
26 Apr 2018, 22:47
26 Apr 2018, 21:51
Via @AlbertFabrega
I believe STR pioneered the bleed slots being opened on the leading edge of the end plate.
Yes STR pionneered that, but Mclaren 'invented' what the last pic shows AFAIR viewtopic.php?p=760106#p760106
Zynerji wrote:
27 Apr 2018, 01:53
26 Apr 2018, 22:47
26 Apr 2018, 21:51
Via @AlbertFabrega
Minardi did large bleed slots in the endplates first. As they became STR it obviously developed from there on.
korzeniow
korzeniow
Why is Renault running rather 'conventional' sidepod deflectors? Most of the teams copied Ferrari's last year's deflectors in some shape or form
February 5, 2013
Via AMuS
designf1
designf1
73
Barcelona - Wednesday
Via AMuS
New endplates.
