You and JAW must be watching Air Crash Investigations on the Lauda Flight 4 crash right now with me then..?
If the duration of the spark is free, and the intensity of the spark is free, they can do more or less what they wan then , cant they?godlameroso wrote: ↑10 Sep 2018, 02:46What a tease, I'd love to see the shaft that's geared to the crank.
In a completely unrelated topic, the regulations allow 5 sparks per cycle, surely the spark itself is capable of creating ROS, near or around the spark gap, well timed sparks during the combustion process can have interesting effects on the reactivity of the fuel during before and after said process.
Interesting photo, is this a gas turbine or jet engine?roon wrote: ↑18 Sep 2018, 21:54Would a twin entry compressor contravene the single-stage rule? Stages apply to both parallel and series contexts?
http://www.enginehistory.org/Museums/CW ... ne1005.jpg
I think they can and here is why. The definition of the Auxiliary Oil Tank is;Sieper wrote: ↑16 Oct 2018, 15:00new 2019 clampdown on oil burn during qualifying:
https://www.racefans.net/2018/10/16/new ... targets-te ams-burning-oil-for-qualifying-boost/
Do you think this will finally make this practice impossible, or can one still engineer around this?
The bolded and italics were added by me and this is where I see the exploitation potential. Could another function be added to the AOT and therefore it is no longer classified as an AOT (its just an oil tank) -> not affected by the AOT rules? Is there are limit to the number of oil tanks?1.32 Auxiliary Oil Tank (AOT) :
An Auxiliary Oil Tank (AOT) is a singular vessel connected to the engine whose sole function is to hold engine oil for the replenishment of the engine lubrication system.
I also do not see an oil consumption limit. I believe this was done via Technical Directive, but I would have thought with a new revision of the Technical Regulations that the TD's would have been incorporated.7.9 AOT
7.9.1 Only one AOT may be fitted to the car.
7.9.2 The total volume of the AOT and its connections to the engine must not be greater than 2.5l.
The transfer of oil between the AOT and the engine must be controlled by a solenoid.
The Nene is both a gas turbine and a jet.subcritical71 wrote: ↑18 Sep 2018, 23:11Interesting photo, is this a gas turbine or jet engine?roon wrote: ↑18 Sep 2018, 21:54Would a twin entry compressor contravene the single-stage rule? Stages apply to both parallel and series contexts?
2 stages refers to 2 stages of compression.subcritical71 wrote: ↑18 Sep 2018, 23:11I would think that the entry would be fine as you could also do a scroll type entry. But since you have two sets of outlet vanes this would be considered two outlet stages... a no go by my thinking.
