2018 Scuderia Toro Rosso F1 Team - Honda
Marti_EF3
56
Re: 2018 Scuderia Toro Rosso F1 Team - Honda
Squid wrote:
23 Jun 2018, 23:27
According to Toro Rosso's head of vehicle performance, Gasly suffered a lot of understeer in his last fast lap in Q2 and they're still not sure what caused it. They're going over the data.
Maybe the wind changed direction?? And that made setup a bit worst?? Or track temp being lower
ispano6
143
From the numbers seems like STR13 is running more rearwing DF. That Gasly is at the bottom of the speed traps makes me think there's still also a mapping and deployment mismatch between simulation and actual running. Hopefully the Austria aero update will help with the mid to high speed corners.
Also, was STR the only team to suffer a power outage in the pit garage? They lost a considerable amount of time first day and the rain in fp3 made it effectively useless. On a good note, Gaslys pace on the SS looked pretty good.
We need a clean race from both cars tomorrow for as much data and running as possible. Team goal has to be finish the race and don't compromise the car in the opening lap.
amho
Marti_EF3 wrote:
24 Jun 2018, 00:25
Squid wrote:
23 Jun 2018, 23:27
Yes it was reported in Autosport live.
There is no Might or Power except with Allah.
techman
techman
-5
the race pace of gaslyis the best of the rest.i hopetheyput him on supersoft and he gets a good start. points are possible. iam optimistic
Singabule
Singabule
I think the mapping is far from perfect hence they rely on heavy rear downforce and lead to heavy understeer. Give honda and STR more time to solve the issue.
McMika98
McMika98
-24
Haas has the best pace of midfield. Given overtaking is impossible, it will be hard to get points unless there is retirements
carisi2k
Singabule wrote:
24 Jun 2018, 04:45
The cars are locked in park ferme rules in Q1 so if understeer wasn't a problem in Q1 then how could engine mapping and rear downforce make such a difference in Q2. A gust of wind is the more likely answer then heavy rear downforce and engine mapping.
Not only that but it wasn't a problem on his first lap in Q2.
Big Tea
carisi2k wrote:
24 Jun 2018, 09:24
Singabule wrote:
24 Jun 2018, 04:45
I suspect they have been playing with the dif and lost the settings after the rain
techman
techman
-5
toro rosso is very sensitive to aero compared to others
carisi2k
Big Tea wrote:
24 Jun 2018, 11:56
It was the one run at the end of Q2 that he had understeer and not the whole of Q1 and Q2. They can't play with the differential once qualifying starts and so your theory is invalid unless something broke. A gust of wind is the most probable explanation.
adrianjordan
GhostF1 wrote:
22 Jun 2018, 09:33
We could potentially see some outrageous aero designs from both STR and RBR with the Honda PU from next year.
One could almost call them "Size Zero" :twisted: :twisted: :twisted: :twisted:
Favourite team: McLaren
nzjrs
60
techman wrote:
24 Jun 2018, 12:37
How do you know this specifically techman
techman
techman
-5
its what brendon said a few weeks ago. toro rosso more sensitive to cross wind than others.
Zynerji
109
techman wrote:
24 Jun 2018, 12:37
* except Williams
restless
restless
making Hartley run 40 laps on US certainly didn't help at all :/
