gruntguru
gruntguru
563
Re: A shameless image thread for the enginephiles
The exploded render of the Motus doesn't show any pushrods or rockers - are they ashamed?
flynfrog
e36jon wrote:
03 Jul 2018, 02:03
Two more V4's. What is the one posted above?
This is a 500cc sleeve valve two stroke by Suter. ~200hp. Their website is funky so Google is your friend here...
https://imageshack.com/a/img923/6615/ZL0cmS.jpg
Next up is the Motus V4. Pushrods! (I didn't search to see if this was already posted, sorry.) 110ci displacement, 180 hp & 126 ft*lbs, 8,500rpm redline.
https://imageshack.com/a/img924/1562/lmf5Xk.jpg
https://imageshack.com/a/img923/296/fXmVuZ.jpg
Apologies for earlier snark at the Tesla motor posting. Not my finest moment...
That Suter is awesome.
roon
roon
412
e36jon wrote:
03 Jul 2018, 02:03
Two more V4's. What is the one posted above? edit: The one above is a KTM 990cc GP1 engine. Yummy.
Next up is the Motus V4. Pushrods! 110ci displacement, 180 hp & 126 ft*lbs, 8,500rpm redline. edit: Too funny that I called out pushrods and then failed to show any. I still came up empty on any actual photos, but found the bottom three images instead...
https://imageshack.com/a/img923/3655/8YBVQd.jpg
https://imageshack.com/a/img924/1804/CKfp2J.jpg
https://imageshack.com/a/img922/7631/1beT63.jpg
All good, I throw the snark around as well, so what goes around comes around. :D That was a KTM MotoGP mill. Not sure of the year. I really like the concept of the Motus engine, half a SBC in my eyes. I'm sure Tommy Cookers or J.A.W. know about the sort of crankshafts all these V4s have. Crossplane, flat, something in between. Some sound really great, like you'd expect half a V8 would. I assume the 919 is flat plane.
J.A.W.
J.A.W.
109
flynfrog wrote:
03 Jul 2018, 04:06
e36jon wrote:
03 Jul 2018, 02:03
The Suter is cool, but aint a Sleeve valve though.
This motorcycle engine is:
J.A.W.
J.A.W.
109
gruntguru wrote:
03 Jul 2018, 03:29
Yeaah, good question gg, the Motus leans heavily.. on highly-developed NASCAR pushrod tech..
but since way back in the day.. there've been motorcycles operating real sophistications, such as this Norton:
621
the Motus has a 75 degree crankshaft giving 0 deg, 345 deg, 435 deg, 630 deg firing sequence
for the sound and big bang theme (no such thing as unjustified publicity when it's free ?)
with 2 counterbalance shafts and GDI
designed by Geoff Goddard (veteran ex-Cosworth) and Jim Sracic (did the counterbalancers)
less than $11000
e36jon
e36jon
66
Wow, 3 cam desmo on a Norton?!? I had no idea they went there... Fancy race solution or was this a production item?
Edit: The unit shown was a proto and the article I saw said it never raced... Cool though. Good link here for more info: https://www.desmodromology.nl/norton-500-single/
Since we are getting our desmo on, I submit the 1989 Ferrari 034/5 3.5L V12 F1 mill. 13,000rpm and 660hp. And desmo, at least in proto form. I'm having a hard time nailing down what's what...
Big Tea
Was it not an attempt to keep them racing in the 60's? Don't think they actually sorted it though (did they?)
gruntguru
gruntguru
563
At least Ferrari had the good sense to put the opening and closing lobes on the same shaft - unlike that crazy Norton arrangement - ohhh the phasing issues - makes my head hurt!!!!
wuzak
wuzak
445
roon wrote:
01 Jul 2018, 10:56
https://youtu.be/t8q-_whNM5A
Surely that would be the F1 engine that took Surtees to the championship in 1964?
In 1964 Ferrari also used a 1.5L V6 and a 1.5L Flat 12.
e36jon
e36jon
66
Greetings Wuzak
I am definitely not the authority on this stuff. I got my info from this site: http://www.italian.sakura.ne.jp/bad_toy ... ine05.html Scroll all the way down as this engine is the last entry. I forgot to mention it in my original post but this was a 5-valve head. Yikes...
From the above site:
For desmo junkies this site is Mecca: https://www.desmodromology.nl/ It really is the end-all be-all for desmo…
Jon
e36jon
e36jon
66
Moar desmo!
I was trying to find more info on the Ferrari Tipo 035/5 engine when I stumbled across this Toyota F1 single cylinder development engine with a desmo valve train. Text from the website (https://www.desmodromology.nl/toyota-formula-one/):
Luca Marmorini designed the Ducati like (older generation 4 valve system) desmo for the Toyota Formula one racer. Toyota thought of a V10 desmodromic F1 engine for improving the performances of their engines. In that period (somewhere between 2002 and 2009) all the solutions were tested. They built a single cylinder head for testing and compared its performance with a pneumatic return valve solution. The Desmo showed the same power of the pneumatic solution, but better performance in the mid range, demonstrating the superiority of the desmo system. The desmodromic engine didn’t race due to the risk of a so complex mechanical system. The Toyota race car had already so many problems at that time, so introducing an other uncertain variable was regarded to be a too high risk. Beautiful professional pictures show details like forked (positioned closer in line opposite each other) camfollower fingers and DLC-coated cams and rockers.
Crazy, right?
Jon
roon
roon
412
roon
roon
412
Big Tea
roon wrote:
10 Jul 2018, 05:53
https://youtu.be/b53VCz_aCGc
Thanks, loved it. Watching the other 5 now :D
