McLaren MCL33
Re: McLaren MCL33
It's even better, the are Vortex Generators that redirect the Airflow around the Top of the Sidepod. :wink:
charliesmithhd
charliesmithhd
67
Re: McLaren MCL33
So why doesn't any other team use vortex generators?
makecry
makecry
19
Re: McLaren MCL33
charliesmithhd wrote:
23 Jul 2018, 12:10
Why do teams have different noses and different FW and Different bargeboard area and different floor? :!: :?: :-({|= :-({|=
Re: McLaren MCL33
23 Jul 2018, 12:10
Different sidepod shapes. No one really uses that sidepod shape anymore. The McLaren variant forces a very sharp downturn to the sidepod which requires vortices for the flow to keep attached.
Teams have found different ways to retain the effects, and imo you can be much more creative with a horizontal element over the top of the sidepod.
charliesmithhd
charliesmithhd
67
Re: McLaren MCL33
would it be possible for McLaren to switch to this concept mid season, or even over the winter?
ScrewCaptain27
577
Re: McLaren MCL33
23 Jul 2018, 21:00
If you mean a Ferrari-style solution with the crash structure on the bottom the answer is no, as it would require an all-new chassis and aero concept. They could, however, adopt the Mercedes solution.
- Serj Tankian
charliesmithhd
charliesmithhd
67
Re: McLaren MCL33
ScrewCaptain27 wrote:
23 Jul 2018, 21:07
23 Jul 2018, 21:00
What concept do redbull have? It would seem more likely for McLaren to copy them
ScrewCaptain27
577
Re: McLaren MCL33
23 Jul 2018, 21:08
23 Jul 2018, 21:07
23 Jul 2018, 21:00
It’s far more similar to Ferrari. Would not fit this car right now.
What Mercedes have done instead is moved the sidepod entry backwards and reshaped the turning vanes to suit, whilst keeping the crash structure in position. This was most probably done to solve issues with airflow off the sidepods as pointed out earlier.
- Serj Tankian
roon
roon
412
Re: McLaren MCL33
23 Jul 2018, 21:08
23 Jul 2018, 21:07
23 Jul 2018, 21:00
Rad inlet on top of the upper side crash structure. McLaren and Merc's are beneath.
ALO_Power
ALO_Power
Re: McLaren MCL33
23 Jul 2018, 12:10
Mercedes does, copied them straight from McLaren.
charliesmithhd
charliesmithhd
67
Re: McLaren MCL33
They only used them in monaco
ALO_Power
ALO_Power
Re: McLaren MCL33
23 Jul 2018, 22:37
You sure it was only in Monaco? I thought they had them in more races as well. They have for sure tho the same rear wing endplates as Renault does as well.
mantikos
mantikos
35
Re: McLaren MCL33
ALO_Power wrote:
23 Jul 2018, 22:36
23 Jul 2018, 12:10
Incorrect - Mercedes used them several years ago on the W04 and W05
charliesmithhd
charliesmithhd
67
Re: McLaren MCL33
Lots of teams used them pre 2017, but now it only seems like McLaren uses them. I think Williams used them last year as well
ALO_Power
ALO_Power
Re: McLaren MCL33
mantikos wrote:
23 Jul 2018, 22:47
ALO_Power wrote:
23 Jul 2018, 22:36
23 Jul 2018, 12:10
Wasn't talking about all years. I mean with post 2017 regulations which imo it makes sense to compare.
