2021 Engine thread
roon
roon
444
Re: 2021 Engine thread
Post Wed Jul 11, 2018 10:15 pm
Maybe Porsche/VW/Audi are waiting for front axle kers to be permitted. The 919 & R18 lines only had front axle, never rear axle, kers. They can build an MGUH. They've been racing one for four years. To the extent that it would have been considered to motor, I wonder if they ever used it to control backpressure to help spool the primary unassisted turbo.
wuzak
wuzak
356
Post Thu Jul 12, 2018 2:53 am
WEC/Le Mans rules only allowed 2 methods of recovering energy. For Porsche it was front wheel MGUK and MGUH on secondary turbine on engine. Audi and Toyota used 4 wheel KERS?
roon
roon
444
Post Thu Jul 12, 2018 3:40 am
Audi opted for front-axle KERS and the superior energy density of diesel fuel for the R18 line. Supposedly they tested an MGUH at the beginning of the regulations change, but they did not use it in competition. Toyota were the only LMP1 competitor to use four-wheel KERS.
The R18 competed in the 2MJ, 4MJ, and 6MJ classes in LMP1 over the years, starting with flywheel energy storage before settling upon Li-ion batteries. In the final iteration of the R18, it was shown that a front axle KERS system could be installed in a high-nose narrow-chassis similar to open wheel racing cars:
wuzak
wuzak
356
Post Thu Jul 12, 2018 5:26 am
Thanks.
So Audi only used one method of energy recovery?
All wheel drive KERS seems sensible to me, as it should be easy to balance front:rear brake bias for the electric machines with the hydraulic brakes bias.
Unlike rear wheel only KERS, which requires they hydraulic system bias to shift forward.
roon
roon
444
Post Thu Jul 12, 2018 6:14 am
Correct. LMP1 have more front weight bias, so there is more braking energy available on the front axle compared to F1. I believe their front and rear tires are the same width, so it made sense for both Porsche and Audi to tax the front wheels with e-drive and relieve the rear tires of any additional drive torque, along with the added benefits of installation simplicity and lightness (one 400hp motor likely lighter than two 200hp motors).
saviour stivala
saviour stivala
-19
Post Thu Jul 12, 2018 12:24 pm
for LM to get on the wrong side of the current four engine manufacturers would be suicidal.
digitalrurouni
digitalrurouni
19
Post Thu Jul 12, 2018 4:04 pm
I am probably in the minority but seems to me that we want close racing and for that we need stable regs. They should stick with what they have got right now. Just keep evolving it. The cars don't sound bad at all. It was actually nice to be able to converse to folks when attending the race in Montreal. They should work on getting the cars better at passing other cars. That's the only thing that's missing in F1. Now we have super close qualis which are hard to predict, we have close racing and drama and all that. Performance of the cars are converging which means drivers are having to dig deeper. Renault and Honda once caught up (inevitable) then it will be an amazing spectacle. Just needs a bit of time and stable regs.
gvera
gvera
Post Thu Jul 12, 2018 6:01 pm
Agree 100%
Zynerji
Zynerji
58
Post Thu Jul 12, 2018 7:51 pm
http://www.racecar-engineering.com/wp-c ... pAud07.jpg
That's what I'm talkin' about!
Unlimited AWDKERS... my favorite!
NL_Fer
NL_Fer
63
Post Wed Jul 25, 2018 6:23 pm
Maybe it has been mentioned before, but how about a simple energy limit on the mgu-h and allowing to keep it? For example 70-80 or 100kw maximum harvesting power and 4 MJ maximum recovery per lap?
That would clamp down development of that area and allow Renault and Honda to catch up. To simple?
Big Tea
70
Post Wed Jul 25, 2018 10:16 pm
I would go the opposite and make it unlimited, and not restrict how it is recovered.
This has to be 'road relevant' for the future.
One test is worth a thousand expert opinions
Post Thu Jul 26, 2018 9:57 am
Car & Driver:
Ferrari Patents Novel Method for Making Turbocharged Engines Sound Better
To unmuffle its turbocharged engines, Ferrari electrifies the turbo.
https://www.caranddriver.com/news/ferra ... ate=072518
And then they expect us to like the current "lawnmover" sounding PU's !! :( :o :(
NL_Fer
NL_Fer
63
Post Thu Jul 26, 2018 8:10 pm
What is the point when one team/manufacturer has a powerunit which has 50 bhp more than the others?
Jolle
Jolle
161
Post Thu Jul 26, 2018 9:26 pm
If they keep the current regs, it will be getting closer, no doubt. And because the tech will be become more common knollage, it will be easier for new companies to join. I think Honda was the worst example for a company to join, being all the way in Japan. That way they are/were unable to scout some engineers from England/Italy or France. Plus the teams over there also were just getting to know what they were dealing with.
I imagine if VW AG would join with one of their brands, they would go shopping for a couple of dozen engineers from Daimler AG and Fiat first.
Another theory I have, every time you put “unlimited “ somewhere in the regs, it favors the team with the biggest budget. In this formula the energy transfer between H and K are free and the boost and sizes of the compressors as well. That I where they can make a difference.
AJI
AJI
36
Post Thu Jul 26, 2018 11:44 pm
...Another theory I have, every time you put “unlimited “ somewhere in the regs, it favors the team with the biggest budget...
To limit or not to limit..? This seems to be a double edged sword in F1.
'Unlimited' gives the big budget teams an advantage in that they can throw huge amounts of money at the blue sky thinkers to come up with new innovations.
'Limited' gives the big teams an advantage in that they can throw huge amounts of money at the blue sky thinkers to 'creatively' get around the limitations and/or the coal face guys to build, and rebuild, and rebuild.., a better mouse trap...
I just read that back. Sorry for the lack of plain English.
