roon
roon
449
Re: A shameless image thread for the enginephiles
Flat 12, actually. From the 4wd '47 Porsche Cisitalia 360. That 'exhaust pipe on the diff' should be for a starter motor shaft.
Interesting history:
In November 1945, Porsche was asked to continue the design of the Volkswagen in France and to move the factory equipment there as part of war reparations. Differences within the French government and objections from the French automotive industry put a halt to this project before it had even begun. On 15 December 1945, French authorities arrested Porsche, Anton Piëch, and Ferry Porsche as war criminals. While Ferry was freed after 6 months, Ferdinand and Anton were imprisoned first in Baden-Baden and then in Paris and Dijon.[27]
While his father was in captivity, Ferry tried to keep the company in business, and they also repaired cars, water pumps, and winches. A contract with Piero Dusio was completed for a Grand Prix motor racing car, the Type 360 Cisitalia. The innovative 4WD design never raced, but the money it received was used to redeem Ferdinand Porsche from prison.
The company also started work on a new design, the Porsche 356, the first car to carry the Porsche brand name. The company then was located in Gmünd in Carinthia, where they had relocated from Stuttgart to avoid Allied bombing. The company started manufacturing the Porsche 356 in an old saw mill in Gmünd. They made only 49 cars, which were built entirely by hand.
-Wikipedia
e36jon wrote:
Wed Jul 25, 2018 4:43 pm
PS, Love the DHL box...
That's a cruel way to describe a Porsche RS Spyder. :lol:
e36jon
e36jon
50
Well played, sir. Laughed out loud re the RS Spyder...
roon
roon
449
dren
287
Wow. Flat-10. Mechanical fuel injection. Supercharged? Exhaust pipe on the diff? Weighs as much as a "Honda!". What is it???
PS, Love the DHL box as HVAC nfix in the background. Good to know Porsche stoops to my level sometimes.
PPS, Is that a 'birdcage' Maserati just peaking out on the right?
It's actually a flat 12 :wink: had a sequential shift 5 speed, dual super chargers. Made just shy of 400hp. It was developed for F1 racing by Porche himself but didn't race due to the war.
edit: Ahhh roon beat me to it! To add to his post, the 4WD was selectable by a lever in the cockpit. It could be used for traction out of slow corners or in wet races but could be reverted to RWD for efficiency gains.
Honda!
dren
287
I forgot about the Crysler, roon. https://en.wikipedia.org/wiki/Chrysler_Patriot
It says they had issues with the flywheel working. Didn't Williams develop one years ago?
What's the piston engine? Looks like a dual sharing the same journal but offset rod locations.
Honda!
roon
roon
449
dren wrote:
Thu Jul 26, 2018 11:30 am
Single-cylinder stationary engine. Home power generator. Honda. The extra pivot attaches to a second conrod and a secondary crankshaft spinning at half crankshaft speed. This alters the stroke of the piston every half four-stroke cycle (360*). The expansion stroke is longer than the compression stroke. In effect: Atkinson cycle, but not through valve timing
roon
roon
449
hpras
hpras
Looks like a Mercury.
strad
269
Roon I was wondering..Is that an outboard?
I agree it looks like some kinda Evinrude or Mercury.
Sir Stirling Moss
hpras
hpras
the Tower of Power.
roon
roon
449
saviour stivala
saviour stivala
-17
1949 Cisitalia 1.5l flat-12.
Cylinders: F12. Notes, the valves seated directly in the head. 3 spur-gear pumps - 2 scavenging 1 pressure. oil pressure feed to nose of crankshaft. no head gaskets, cast iron cylinders seats directly in head. cylinder centres: 69mm. Hirth build-up crankshaft running in roller bearings.
Bore: 56mm.
Stroke: 50.5mm.
Stroke/bore ratio: 7.6:1.
Capacity: 1,493cc.
Compression ratio: 7.6:1.
Connecting rod length: 101.6mm.
Rod/crank radius ratio: 4.0:1.
Main bearing journal diameter: 55mm.
Rod journal diameter: 54mm.
Inlet valve diameter: 34mm.
Exhaust valve diameter: 29mm.
Inlet pressure: 3.07Atm.
Peak power: 340bghp @ 10,000rpm. Piston speed (corrected) 18.3m/s. engine bhp per litre: 227.7bhp/litre.
strad
269
Citroen 2CV Chopper
Sir Stirling Moss
strad
269
1967-512-Ferrari-V12
Sir Stirling Moss
roon
roon
449
