McLaren MCL33
zoroastar
zoroastar
Re: McLaren MCL33
diffuser wrote:
07 Aug 2018, 01:45
I don't think taking up more space is gonna help you. If anything it's gonna hurt.
https://pbs.twimg.com/media/DWtAnT5VwAACdwz.jpg
that wideangle lens does wonders for length... i think mclaren do have the shortest wheelbase this year?
Re: McLaren MCL33
They were middle of the pack last year. I haven't seen any numbers from this year ... They were between RBR and Renault, there was a 8cm difference between the 3 and Renault was the long one.
M840TR
M840TR
313
Re: McLaren MCL33
diffuser wrote:
07 Aug 2018, 23:02
Since Haas, Sauber and FI purchase suspension, packaging and cooling solutions etc from Merc and Ferrari, they probably have a long wheelbase car too.
Re: McLaren MCL33
M840TR wrote:
08 Aug 2018, 11:46
diffuser wrote:
07 Aug 2018, 23:02
Not necessarily. If the merc and ferrari gearboxes have a shroud for the suspension, you can do some adaptations.
DFX
DFX
Re: McLaren MCL33
turbof1 wrote:
08 Aug 2018, 11:49
M840TR wrote:
08 Aug 2018, 11:46
diffuser wrote:
07 Aug 2018, 23:02
Haas at least has the exact same dimensions as the Ferrari, so it might be true to the others aswell.
M840TR
M840TR
313
Re: McLaren MCL33
turbof1 wrote:
08 Aug 2018, 11:49
M840TR wrote:
08 Aug 2018, 11:46
diffuser wrote:
07 Aug 2018, 23:02
You can tell by the turning angle on the bargeboards.
Re: McLaren MCL33
Ah my bad, I was talking about the rear suspension. I think the front suspension is still highly adaptable and really depends on the chassis design.
zoroastar
zoroastar
Re: McLaren MCL33
i think i was confusing shortest wheelbase with shortest front to back. i could have sworn i read that somewhere. i think mclaren did lengthen the rear by increasing width of the gearbox. dont know anything about the front.
M840TR
M840TR
313
Re: McLaren MCL33
zoroastar wrote:
08 Aug 2018, 17:36
Yes, the bell housing is a bit longer this year due to the Renault engine design.
Re: McLaren MCL33
M840TR wrote:
08 Aug 2018, 18:13
zoroastar wrote:
08 Aug 2018, 17:36
The Bell housing was lengthened because the Renault doesn't have 6"-10" compressor on the front of the PU. So the Renault PU sits further forward.
Re: McLaren MCL33
This is making the most of what you got ...
Notice the sidepods start, roughly, on the inside front of the halo for both cars.
But when you look at the RB14 from the side ... There is no Sidepod there, just a crash structure that's holding up the mid wing. The sidepod starts furtherback.
M840TR
M840TR
313
Re: McLaren MCL33
diffuser wrote:
09 Aug 2018, 17:05
https://media-cdn.mclaren.com/media/ima ... bsite4.jpg
http://www.michaelpotts.com/images/form ... image1.jpg
https://cdn-4.motorsport.com/images/amp ... 680118.jpg
Doesn't fit to their design philosophy. They have to keep a much wider sidepod for the vortex generators to work. Plus if they went the RB way they'd compromise the intercoolers which itself compensate for the narrow upper body.
Nonserviam85
Nonserviam85
Re: McLaren MCL33
M840TR wrote:
09 Aug 2018, 19:18
diffuser wrote:
09 Aug 2018, 17:05
But this is the issue, this design seems to underperform compared to the tall and narrow sidepod design. The Renault PU might have different packaging requirements but Red Bull made it work, so I guess McLaren should be looking that way.
M840TR
M840TR
313
Re: McLaren MCL33
Nonserviam85 wrote:
09 Aug 2018, 22:10
M840TR wrote:
09 Aug 2018, 19:18
diffuser wrote:
09 Aug 2018, 17:05
This is not the issue. It's a less ambitious sidepod design that's all. Their issues are some fundamental aero flaws that would take months worth of R&D. Renault's is even less aggressive but they were 0.8 sec ahead in Germany.
charliesmithhd
67
Re: McLaren MCL33
M840TR wrote:
09 Aug 2018, 22:52
Nonserviam85 wrote:
09 Aug 2018, 22:10
M840TR wrote:
09 Aug 2018, 19:18
It does seem that McLaren has a larger surface area around the side pod inlet compared to redbull and renault
