Brakes idea
manchild
22
Brakes idea
Post by manchild » Fri Aug 10, 2018 9:59 am
An old idea of mine which I've never presented. I was thinking of a lock that would connect disc instantly when pedal is touched and unlock it when foot is raised so that disc spin freely without actually adding the weight to the wheel during acceleration, and have much less intertia before braking. It would improve both the braking effectiveness and acceleration.
When driver touches the pedal, the disc would actually begin the braking process due to its weight that needs to be accelerated, even before the pads engage, and slightly cool themselves just before the heating up under braking.
I reckon that it could also be used when driver needs to additionally cool discs on the straight, with just touching the peddal.
It would also enable the disc to maintain its speed during slowdowns without braking, thus maintain its cooling.
And possibly, if accordingly designed, the air pressure from the brake inlet could do the spinning of the disc and level up in a way, likely reducing the drag.
4 discs x approximately 1kg = 4kg less to accelerate, with ditched inertia under braking.
bucker
Re: Brakes idea
Post by bucker » Fri Aug 10, 2018 10:10 am
Pictures, sketches,....
manchild
22
Re: Brakes idea
Post by manchild » Fri Aug 10, 2018 10:14 am
bucker wrote: โ†‘
Well, it would be far fetched for me to design the actual device. I reckon that would require an f1 engineer ๐Ÿ˜‰
Re: Brakes idea
Post by Just_a_fan » Fri Aug 10, 2018 10:15 am
Would the system's benefit offset the issue of adding the weight of the locking mechanism to the unsprung weight?
Turbo says "Dumpster sounds so much more classy. It's the diamond of the cesspools."
zac510
37
Re: Brakes idea
Post by zac510 » Fri Aug 10, 2018 10:16 am
Like the freewheel hub of a bicycle, but fitted in reverse?
manchild
22
Re: Brakes idea
Post by manchild » Fri Aug 10, 2018 10:25 am
Indeed. And to reply to Just_a_fan, definitely, but having in mind how tiny it would have to be, guess that benefits would greatly surpass the small weight added to upright.
Dr. Acula
22
Re: Brakes idea
Post by Dr. Acula » Fri Aug 10, 2018 10:43 am
Not in F1 my friend, not in F1.
11.3.1 No more than one brake disc is permitted on each wheel which must have the same rotational velocity as the wheel it is connected to.
manchild wrote: โ†‘
Actually this would increase drag. You can design the brake disc like an radial impeller, that's not a problem at all and is already done in some brake discs to improve the airflow a bit. But the energy to turn the disc has to come from somewhere if not from the wheel.
rscsr
63
Re: Brakes idea
Post by rscsr » Fri Aug 10, 2018 10:50 am
manchild wrote: โ†‘
An old idea of mine which I've never presented. I was thinking of a lock that would connect disc instantly when pedal is touched and unlock it when foot is raised so that disc spin freely without actually adding the weight to the wheel during acceleration, and have no intertia before braking. It would improve both the braking effectiveness and acceleration.
There are some problems with that idea.
The wheel assembly has about 10kg. If we assume the mass distribution can be approximated as a disc we get an inertia of about . With the same approximation for the disc (1kg, r=139mm) we get about . That means the brake disc contributes to the total inertia of the wheel assembly only 2.5%.
When we assume the only relevant inertia for our purposes comes from the 4 tyres we can calculate the effective mass during acceleration as
Or in other words the total rotating mass of the wheels reduce the acceleration by 2.7% and the inertia of the brake discs only 0.0675%.
So in short even if it would work as intended it had barely any effect on the performance.
Additionally the freewheeling part would need to withstand all of the breaking forces (ergo heavier than the bolts used now), would need to be able to accelerate a standing brake disc within a fraction of a second and fit into an already cramped space.
manchild
22
Re: Brakes idea
Post by manchild » Fri Aug 10, 2018 10:52 am
Thanks for the bad news Dr. Aacula ๐Ÿ˜€
Perhaps it could find its use in other series or automobile industry.
Any idea why that rule was ever defined?
Thanks for the math rscsr ๐Ÿ˜‰
roon
359
Re: Brakes idea
Post by roon » Fri Aug 10, 2018 11:04 am
zac510 wrote: โ†‘
That would not transmit braking torque from the rotor to the hub.
Dr. Acula
22
Re: Brakes idea
Post by Dr. Acula » Fri Aug 10, 2018 11:41 am
manchild wrote: โ†‘
Well it's a guess, but probably to prevent a geared setup. The relative small brake discs used in F1 create some problems with brake application. Small discs mean you have to apply more force on the brake discs to achieve the same brake torque because of the shorter lever. (distance between the axle and the center line of the brake pad...more or less) This often results in a less sensitive brake pedal which can cause more lockups.
The rules prevent indirectly discs with a larger diameter, but what you could do in theory is to let the brake discs run on the outside of a small planetary gearbox which would have the same effect as a larger diameter brake disc, by increasing torque for the brake disc but let it turn slower so it's harder to lock it up.
496
Re: Brakes idea
Post by Tommy Cookers » Fri Aug 10, 2018 12:58 pm
there was a race motorcycle that had its front brake discs gear-driven (at higher than wheel speed iirc)
but this gearing was the reverse of the wheel rotation
so the disc rotation largely cancelled the gyroscopic effects due to the wheel rotation
at one time some cars had a transmission brake
Re: Brakes idea
Post by Just_a_fan » Fri Aug 10, 2018 4:30 pm
manchild wrote: โ†‘
Would it be small/light? Whatever device is used, it must not break. Having that device fail at the point of braking at 300km/h and causing the car to rotate around the still working front wheel and in to the barriers would be a bad thing. The barriers are often lightly protected in the braking zone - usually without the multiple layers of tyres seen elsewhere.
hollus
Re: Brakes idea
Post by hollus » Sat Aug 11, 2018 5:46 pm
I can't believe I am suggesting that the rule makes did anything right, but... safety first?
Maybe they added the rule to prevent systems like this, that, while adding performance, increase the chances of brake failure? Brakes simply M-U-S-T work at all times. Also, imagine if in a freak accident, your fastly rotating brake disk works itself free from the rest of the wheel and the car?
That said, maybe the rule was added just because whoever makes them is paid by word? /off-topic.
...not because they are easy, but because they are hard!
roon
359
Re: Brakes idea
Post by roon » Sat Aug 11, 2018 7:14 pm
Tommy Cookers wrote: โ†‘
I remember reading about that as well. Would this not reduce the bike's tendency to upright itself?
