Brakes idea
manchild
manchild
Brakes idea
An old idea of mine which I've never presented. I was thinking of a lock that would connect disc instantly when pedal is touched and unlock it when foot is raised so that disc spin freely without actually adding the weight to the wheel during acceleration, and have much less intertia before braking. It would improve both the braking effectiveness and acceleration.
When driver touches the pedal, the disc would actually begin the braking process due to its weight that needs to be accelerated, even before the pads engage, and slightly cool themselves just before the heating up under braking.
I reckon that it could also be used when driver needs to additionally cool discs on the straight, with just touching the peddal.
It would also enable the disc to maintain its speed during slowdowns without braking, thus maintain its cooling.
And possibly, if accordingly designed, the air pressure from the brake inlet could do the spinning of the disc and level up in a way, likely reducing the drag.
4 discs x approximately 1kg = 4kg less to accelerate, with ditched inertia under braking.
bucker
bucker
Re: Brakes idea
Pictures, sketches,....
manchild
manchild
Re: Brakes idea
bucker wrote:
10 Aug 2018, 11:10
Well, it would be far fetched for me to design the actual device. I reckon that would require an f1 engineer 😉
Re: Brakes idea
Would the system's benefit offset the issue of adding the weight of the locking mechanism to the unsprung weight?
zac510
zac510
22
Re: Brakes idea
Like the freewheel hub of a bicycle, but fitted in reverse?
manchild
manchild
Re: Brakes idea
Indeed. And to reply to Just_a_fan, definitely, but having in mind how tiny it would have to be, guess that benefits would greatly surpass the small weight added to upright.
Dr. Acula
Dr. Acula
46
Re: Brakes idea
Not in F1 my friend, not in F1.
11.3.1 No more than one brake disc is permitted on each wheel which must have the same rotational velocity as the wheel it is connected to.
manchild wrote:
10 Aug 2018, 10:59
Actually this would increase drag. You can design the brake disc like an radial impeller, that's not a problem at all and is already done in some brake discs to improve the airflow a bit. But the energy to turn the disc has to come from somewhere if not from the wheel.
rscsr
51
Re: Brakes idea
manchild wrote:
10 Aug 2018, 10:59
An old idea of mine which I've never presented. I was thinking of a lock that would connect disc instantly when pedal is touched and unlock it when foot is raised so that disc spin freely without actually adding the weight to the wheel during acceleration, and have no intertia before braking. It would improve both the braking effectiveness and acceleration.
There are some problems with that idea.
The wheel assembly has about 10kg. If we assume the mass distribution can be approximated as a disc we get an inertia of about . With the same approximation for the disc (1kg, r=139mm) we get about . That means the brake disc contributes to the total inertia of the wheel assembly only 2.5%.
When we assume the only relevant inertia for our purposes comes from the 4 tyres we can calculate the effective mass during acceleration as
Or in other words the total rotating mass of the wheels reduce the acceleration by 2.7% and the inertia of the brake discs only 0.0675%.
So in short even if it would work as intended it had barely any effect on the performance.
Additionally the freewheeling part would need to withstand all of the breaking forces (ergo heavier than the bolts used now), would need to be able to accelerate a standing brake disc within a fraction of a second and fit into an already cramped space.
manchild
manchild
Re: Brakes idea
Thanks for the bad news Dr. Aacula 😀
Perhaps it could find its use in other series or automobile industry.
Any idea why that rule was ever defined?
Thanks for the math rscsr 😉
roon
roon
412
Re: Brakes idea
zac510 wrote:
10 Aug 2018, 11:16
That would not transmit braking torque from the rotor to the hub.
Dr. Acula
Dr. Acula
46
Re: Brakes idea
manchild wrote:
10 Aug 2018, 11:52
Well it's a guess, but probably to prevent a geared setup. The relative small brake discs used in F1 create some problems with brake application. Small discs mean you have to apply more force on the brake discs to achieve the same brake torque because of the shorter lever. (distance between the axle and the center line of the brake pad...more or less) This often results in a less sensitive brake pedal which can cause more lockups.
The rules prevent indirectly discs with a larger diameter, but what you could do in theory is to let the brake discs run on the outside of a small planetary gearbox which would have the same effect as a larger diameter brake disc, by increasing torque for the brake disc but let it turn slower so it's harder to lock it up.
670
Re: Brakes idea
there was a race motorcycle that had its front brake discs gear-driven (at higher than wheel speed iirc)
but this gearing was the reverse of the wheel rotation
so the disc rotation largely cancelled the gyroscopic effects due to the wheel rotation
at one time some cars had a transmission brake
Re: Brakes idea
manchild wrote:
10 Aug 2018, 11:25
Would it be small/light? Whatever device is used, it must not break. Having that device fail at the point of braking at 300km/h and causing the car to rotate around the still working front wheel and in to the barriers would be a bad thing. The barriers are often lightly protected in the braking zone - usually without the multiple layers of tyres seen elsewhere.
hollus
Re: Brakes idea
I can't believe I am suggesting that the rule makes did anything right, but... safety first?
Maybe they added the rule to prevent systems like this, that, while adding performance, increase the chances of brake failure? Brakes simply M-U-S-T work at all times. Also, imagine if in a freak accident, your fastly rotating brake disk works itself free from the rest of the wheel and the car?
That said, maybe the rule was added just because whoever makes them is paid by word? /off-topic.
¡Puxa Sporting!
roon
roon
412
Re: Brakes idea
Tommy Cookers wrote:
10 Aug 2018, 13:58
I remember reading about that as well. Would this not reduce the bike's tendency to upright itself?
