1994-2009 F1 Technical Regulations
mariof1
mariof1
Believe if you will.
I came across this totally by chance:
http://www.jomenvisst.de/fia/
I know many of you will appreciate that so... enjoy.
Scotracer
Scotracer
Re: 1994-2009 F1 Technical Regulations
Oh you're a gem -- I've been looking for these for ages! Cheers!
Just looked up the 1997 regulations and I really wish today it were like this:
ARTICLE 5 : ENGINE
5.1) Types of engine permitted
Only 4-stroke engines with reciprocating pistons are permitted.
5.2) Maximum capacity
Engine capacity must not exceed 3000cc.
5.3) Supercharging
Supercharging is forbidden.
5.4) Number and type of cylinders
The maximum number of cylinders is 12 and the normal section of each cylinder must be circular.
5.5) Number of valves
Engines may have no more than 5 valves per cylinder.
5.6) Temperature and pressure of the charge
5.6.1 - Any device, system, procedure, construction or design the purpose and/or effect of which is any decrease whatsoever of the temperature of the intake air and/or of the charge (air and/or fuel) of the engine is forbidden.
5.6.2 - Internal and/or external spraying of water or any substance whatsoever is forbidden (other than fuel for the normal purpose of combustion in the engine).
5.7) Exhaust system
Variable geometric length exhaust systems are forbidden.
5.8) Engine materials
5.8.1 - The basic structure of the crankshaft and camshafts must be made from steel or cast iron.
5.8.2 - Pistons, cylinder heads and cylinder blocks may not be composite structures which use carbon or aramid fibre reinforcing materials.
How much would that rock? :(
Powertrain Cooling Engineer
bazanaius
bazanaius
Mario I want your babies.
Ogami musashi
Ogami musashi
32
You made my day marioF1 , thank you!
gold333
gold333
no text
F1 car width now 2.0m (same as 1993-1997). Lets go crazy and bring the 2.2m cars back (<1992).
timbo
timbo
113
Great! Thanks!
SeijaKessen
THANK YOU MARIO!!!!!!!!!!!!!!!!!!
This is fantastic.
Wish they had regulations from the mid-1970s through the 1980s too.
