All images from FIA.com
That is quite awesome.garyjpaterson wrote: ↑Fri Nov 23, 2018 12:41 pmThrew together a spline model based on camera matching (not final but pretty close imo), which I can use to make a 3d model of it should I find the time.
Would love some accurate dimensions though to help verify it - wheelbase/track width etc, or even a wing/floor width if possible. Not sure why no real dimensions were published.
https://i.gyazo.com/634e44ee5626b07863d ... 45ca00.gif
But overall after comparing to the GP3 car, there are a lot more changes than meets the eye. Front suspension geometry is quite different for a start!
I actually made one a few days earlier for the GP3 car in preparation as I was pretty convinced the F3 car would be very similar (and I was right!) -rscsr wrote: ↑Fri Nov 23, 2018 12:48 pmThat is quite awesome.garyjpaterson wrote: ↑Fri Nov 23, 2018 12:41 pmThrew together a spline model based on camera matching (not final but pretty close imo), which I can use to make a 3d model of it should I find the time.
How are you doing that? I was looking several times for something like this, but the results were usually awful.
That is super cool!!!!!garyjpaterson wrote: ↑Fri Nov 23, 2018 12:41 pmThrew together a spline model based on camera matching (not final but pretty close imo), which I can use to make a 3d model of it should I find the time.
Ah nice, great info! Although I can't quite beleive that wheelbase number, should be closer to 3000mm? I'm at 2880mm for my model right now.jjn9128 wrote: ↑Fri Nov 23, 2018 1:02 pmThat is super cool!!!!!garyjpaterson wrote: ↑Fri Nov 23, 2018 12:41 pmThrew together a spline model based on camera matching (not final but pretty close imo), which I can use to make a 3d model of it should I find the time.
I don't think the key dimensions are different from last year:
Minimum wheelbase is 2000mm,
Maximum width is 1850mm (wheels steered straight ahead),
Maximum floor width is 1300mm,
Overall height is 860mm,
Width behind the RWCL is 900mm,
Front wing is 1600mm wide,
The cockpit opening will be 850mm long.
As I say, hopefully enough of these will be the same as last year. Failing that there are detailed drawings for the halo in the 2018/19 Formula E regs.
The bar diameter is 50mm,
Maximum width is 630mm,
Height from cockpit surround to apex of the Y is 156.3mm,
The maximum width of the Y is 365.1mm,
The centre of the front fixing to the front of the rear fixing is 835mm.
Yeah looking at it... 1300mm is too narrow for bodywork if the max width is 1850mm...garyjpaterson wrote: ↑Fri Nov 23, 2018 1:06 pmAh nice, great info! Although I can't quite beleive that wheelbase number, should be closer to 3000mm? I'm at 2880mm for my model right now.
Yeah I dont think those F3 regs are really related to the GP3/new F3 car, its a different class of car altogether really.jjn9128 wrote: ↑Fri Nov 23, 2018 1:09 pmYeah looking at it... 1300mm is too narrow for bodywork if the max width is 1850mm...garyjpaterson wrote: ↑Fri Nov 23, 2018 1:06 pmAh nice, great info! Although I can't quite beleive that wheelbase number, should be closer to 3000mm? I'm at 2880mm for my model right now.
I can't find a rulebook on the FIA site for GP3
The Ligier JS F3 was built to FIA F3 regs and has wheelbase = 2920mm. The bodywork between the wheels is also 1500mm wide.
I know - but they look like they take a lot of DNA from the GP3 chassis. e.g. the front wing mainplane and endplates look almost entirely carried over.garyjpaterson wrote: ↑Fri Nov 23, 2018 1:12 pmYeah I dont think those F3 regs are really related to the GP3/new F3 car, its a different class of car altogether really.
Absolutely, the floor leading edge and T tray etc also seem to be pretty much the same. Which strongly suggests the new F3 has nothing in common with the regional F3 regs which are their own class altogether.jjn9128 wrote: ↑Fri Nov 23, 2018 1:14 pmI know - but they look like they take a lot of DNA from the GP3 chassis. e.g. the front wing mainplane and endplates look almost entirely carried over.garyjpaterson wrote: ↑Fri Nov 23, 2018 1:12 pmYeah I dont think those F3 regs are really related to the GP3/new F3 car, its a different class of car altogether really.
I suppose the steel halo is because the speeds are lower.
