HALO Approved for 2018
Formula Wrong
Re: HALO Approved for 2018
Post Mon Nov 26, 2018 12:54 am
NathanOlder wrote:
Sun Nov 25, 2018 9:19 pm
If the car ends up like Perez in Budapest , the side he escaped from would have had a Halo bar running through the middle of it!
Wasn't that exactly the scenario they showed in their presentation last year that a driver can get out with the Halo? Car ending up upside down, slightly on its sidee?
If you no longer go for the space someone always has to leave, you're no longer a racing driver
Post Mon Nov 26, 2018 2:17 am
Yes, but it was leaning in opposite direction, with the exit point towards the barriers, into which the renault was actually landed/shoved into, so there was no way to comfortably or realistically exit.
It is a thing though to concider, the fire danger. it's so funny how much people were screaming about there have been no fires, but you just saw exactly happening that; a fire. given, it wasn't a full blaze thank god, but it shows how easily it can happen in an accident.
offcourse, the marshalls were there pretty fast and it was out in just a moment, but again, what if this turned into something much bigger? definately a thing to think about.
glad though it ended all with just a little rollercoaster and nothing harmed physically. it was pretty scary.
Dumpster sounds so much more classy. It's the diamond of the cesspools.
Post Mon Nov 26, 2018 2:20 am
NathanOlder wrote:
Sun Nov 25, 2018 7:44 pm
Its the FIA . Thought and rehearsals arent likely. They spend their days making videos of how easy it is to get out of a car when upside down, a car with no wheels so the car could roll over and leave space to get out.
I'm glad all those that told me getting out would be easy are now proven wrong.
this 100%.
BTW, i personally found it extremely but extremely suspicious, that when we got the onboard shots of hulkenberg, that before the car actually flipped over, they cut away and never after shown the onboard shots. were they hiding something there in regards to escaping? i don't think the camera survived the rollarcoaster ride anyway, but i found it too odd that they cut to exactly that shot and then right before contact, they cut away.
or am i missing actual full footage?
Cannonballer
Cannonballer
Post Mon Nov 26, 2018 8:22 am
this 100%.
I just watched the onboard footage from Hulkenberg's car on F1TV. It is odd, the video feed goes out almost immediately after the initial contact with Grosjean.
Wazari wrote: There's a saying in Japan, He might be higher than testicles on a giraffe...........
zac510
zac510
39
Post Mon Nov 26, 2018 8:36 am
Is it really necessary to have speedy exit times in series like F1, F2, FE where there are half a dozen marshals at every corner to put out fires and full course safety cars to neutralise the circuit? If the driver is injured then he can't self-extract anyway, the medical car needs to attend and at that time marshals can work.
Of course at some club or national meeting where there are 1/3 the amount of marshals it would be different.
NathanOlder
128
Post Mon Nov 26, 2018 8:45 am
Again, that video the car has no wheels, no suspesion, no wings, no PU, no fuel tank ect.
The airbox is not even touching the ground, So add the weight of a gearbox, Engine, hybrid system with heavy battery, fuel tank, rear wheels and rear suspension then the airbox will now sit on the ground (gap to escape reduced)
Now consider the side of the car on the ground (The drivers right hand side, or the side we cant see in that vid) add some suspension, tethered wheels to that side and its very likely the right hand side of the car will be propped up higher therefore rotating the car more upside down, and again reducing the gap to escape.
Then see how tricky it was to get out despite all these parts of the car missing, then you can see how a driver like Hulkenberg couldnt get out at all. I'm not quite sure how Hulkenbergs camera survived ? Is it something that has been reinforced to increase the gap to escape ? If so I never heard anything about it so it was done on the quiet :?:
GoLandoGo
Lewis v2.0
Does anyone play F1 2019 on Ps4, Now setting up a league at
https://rapidpixelracing.com
Diesel
Diesel
53
Post Mon Nov 26, 2018 10:23 am
Yes, that's why the FIA have their own extraction tests. Cars can go up in flames very quickly, and re-light even after being extinguished. The extinguisher itself isn't exactly non-toxic, I can't imagine hanging upside down in a cloud of extinguisher was particularly nice for Hulkenberg, his radio wasn't easy listening either.
Surely with all the tech in F1 they can come up with a solution, perhaps a removable section on each side of the cockpit, like a single use door?
"Unbelievable how silly this Formula 1 is these days, with this stupid overtakes."
—Sebastian Vettel, 2012 US GP
Tim.Wright
444
Post Mon Nov 26, 2018 10:34 am
Interestingly, that mockup scene shows the roll hoop off the ground which wouldn't be the case if the engine + transmission was still attached.
WaikeCU
71
Post Mon Nov 26, 2018 10:59 am
What worries me the most is when a big accident occurs where the driver is in a critical condition with the car upside down. Imagine an accident similar to Kubica's. I haven't clocked it, but it took quite a while to flip the car and to get Nico out of the car. To me the HALO protects the head of the driver in certain accidents (which is good), but it's more difficult to access the driver for medical treatment and that's worrying.
gibells
gibells
Post Mon Nov 26, 2018 11:12 am
Isn't this just something the editors do in case there are terminal consequences to any accident. The last thing you want is views of the cockpit in the driver's last moments strewn across the internet.
Formula Wrong
Post Mon Nov 26, 2018 11:43 am
True, so far we don't know how a full car with Halo would rest on the ground. Though in Hulk's case the airbox wasn't touching the ground either since the car was resting on the tecpros
Hulk's onboard doesn't look much different to me than other onboards from similar accidents in the past few years?
https://youtu.be/Jc2nsX4-Q54?t=25
https://youtu.be/FMn43oSLxuc?t=16
https://youtu.be/4o9TYzGy_q0?t=20
I don't think we need to interpret too much into it. Cameras can break, they're not made to be indestructable.
NathanOlder
128
Post Mon Nov 26, 2018 1:39 pm
Exactly, yet the FIA have said its fine and you can still get out, without testing this !!!! Does that not seem a little bloody silly ?! We've had 20 cars do 21 races which involve 5 sessions. So thats 525 times an F1 car has gone to the track with a Halo on it, and we dont know how the car sits when its upside down, yet the FIA and many on here (no saying you are one of them) telling us (me) that its fine, the driver will still get out no problem!
GoLandoGo
Lewis v2.0
Big Tea
70
Post Mon Nov 26, 2018 2:11 pm
What ever the truth of it, the very worst thing that can happen is another knee jerk response without thinking it through.
There is a thin line of things you just can do nothing about, and those that happen so infrequently it is not worth including the risk it causes at other times.
It needs more research, not 'instant response'
One test is worth a thousand expert opinions
Formula Wrong
Post Mon Nov 26, 2018 3:20 pm
To be completely honest, I'm not entirely sure whether I'd agree or disagree to that.
On one hand you're right, if there has been no testing on this there might be some risk that hasn't been looked at enough.
On the other hand the FIA probably has more data available than any of us and probably/hopefully has at the very least done some evalutaion of the risks involved in different scenarios (and has done more than the one test we've seen).
It's not always a bad thing when the driver has to wait for the car to be turned over on its floor before getting out; in fact that has been the preferred procedure in some cases (e.g there have been two cases in German F4 last year, where the cars don't have a Halo yet).
But then there's also a bunch of "what if" scenarios. I've seen fire mentioned in many discussions and while I can't recall any big fire that was a serious threat for the driver after a crash in recent years (after all the cars nowadays don't explode into huge fireballs anymore and small fires like in Hulk's case aren't that much of a problem (or are they?)), the thought of a driver being stuck while for some reason the entire car is on fire definitely is scary. But if a crash damaged the battery it might be better to stay in the cockpit if you don't want to get electrocuted when touching the ground etc. etc.
We can only speculate about those but personally I do hope that the FIA has looked at those risks and found out that even with those things in mind having the Halo is still beneficial overall.
zac510
zac510
39
Post Mon Nov 26, 2018 3:30 pm
Largest unattended fire I can recall was Webber's RBR in Korea, (edit: 2013 https://www.youtube.com/watch?v=iac5J0adxxw).
