saviour stivala wrote:
Mon Nov 19, 2018 11:13 am
This discussion reinforced my opinion that in F1 the ECU limp-home and shut-down modes to avoid catastrophic engine failure is not used.
Only when things really become terminal. Above all, it is still a competition and going into limp home/shut down mode means forfeiting the race. I think they'd much more prefer the risk on damage and see if they can correct the issue, which is what Mercedes did. They have confirmed there is damage (which I think will likely lead to a PU change), but the trade off is that they won the race.
But yes, there are fail safes in place. I think this happened to Renault a couple of years ago on Spa.
If lambda sensor is broken there will not be signals to ECU
Note that having an issue on a sensor does not immediately mean it is outright broken. A faulty sensor could just as well send out wrong measurements to the ECU. This is what I definitely had on my car because the car not did go into any safe mode; the check engine light just flickered on my dashboard. The lambda sensor still was active, but was faulty (the engine had a correct combustion) and both tried to change combustion (which would be a wrong correction) and send an indication to my dashboard.
It's difficult to make any reasonable guess on how this all works out in a F1 PU, which is loaded up with dozens and dozens of sensors. It takes a whole department back at the home base of Mercedes just to keep an eye out on telemetry. So definitely it is vastly complicated. And let's not forget, it doesn't have to be a sensor issue.
saviour stivala
saviour stivala
-4
turbof1 wrote:
Mon Nov 19, 2018 11:38 am
Yes, and as I just told henry, "and that is what Mercedes did".
Mon Nov 19, 2018 12:04 pm
Obviously. Problem is that that is no indicator of the specific issue, only that they were able to somehow manage it.
saviour stivala
saviour stivala
-4
turbof1 wrote:
Mon Nov 19, 2018 1:11 pm
And that besides the fact that we can only talk about what they chose to push-out. One such push-outs that didn’t really made sense to me was having to “replace Bottas engine after a “hydraulic system failure”. remember that?
Mon Nov 19, 2018 1:23 pm
To be fair, a "hydraulics system failure" could almost mean anything. F1 teams have been saying that for years now to the media, to say really nothing at all.
Therefore, it's best to speculate and do conjecture (in a sensible way, mind you). Nobody is making absurd conclusions, just hypetheses.
Mudflap
350
I guess my sources were correct after all.
https://www.autosport.com/f1/news/14027 ... er-problem
"The problem in Brazil was caused by a failure in the variable inlet system that caused unstable combustion," said a Mercedes spokesperson.
nah pop no style
henry
311
Here’s a comment from Andrew Shovlin on Autosport
"You always struggle a bit more with overheating in FP1 but other than that, the car seemed to be working OK."
The question is why? Do turned down engines run hotter than engines running at full power?
Phil
430
Isn't that comment perhaps due to time of FP1 at Abu Dhabi, e.g. at 'daytime' where as FP2, QF and the race are at twilight/night? :oops:
#Team44 supporter
henry
311
Phil wrote:
Fri Nov 23, 2018 9:39 pm
There is that distinct possibility.
Bottas confirmed this. He said the car is set up for the colder night (cooling. Tyres. Etc.). But FP1 is in the day.
Not driving a Mercedes? Work harder!
dren
288
Mudflap wrote:
Fri Nov 23, 2018 12:36 pm
I wonder how much of the tuned pulsing benefits the combustion. It must rely on it if a failure in the system caused it to be unstable.
Honda!
gruntguru
gruntguru
474
dren wrote:
Tue Nov 27, 2018 5:34 pm
If the runner length is not optimal for the current engine speed, the cylinder fill will be reduced resulting in a richer AFR. Undesired AFR will have an effect on combustion stability.
dren
288
gruntguru wrote:
Wed Nov 28, 2018 12:54 am
Right, but will it have such a big impact with the engine being FI?
Honda!
gruntguru
gruntguru
474
dren wrote:
Wed Nov 28, 2018 12:14 pm
Potentially yes. We need to remember that the combustion conditions in these engines are at the very limit on a number of parameters. I would guess things like peak cylinder pressure, rate of pressure rise, detonation, heat input to various components (exhaust valve, piston crown). A richer mixture (remember these things are running ultra-lean and a richer mixture will increase combustion temp, flame speed, detonation etc) could easily tip one or more of these parameters over the edge, necessitating compromises to operating parameters (like ignition timing) to protect the engine.
But one would think a richer burn would be more stable?
If I had to hazard a guess, I would say the VLIM influences not just the AFR but the aerodynamics inside the cylinders. I would love to go deeper but we don't have confirmation on the TJI layout inside the Mercedes cylinder.
