Specifications of 50 famous racing engines up to 1994
gruntguru
563
Re: Specifications of 50 famous racing engines up to 1994
That Delage engine is a work of art.
saviour stivala
51
That was a time when pride in appearance was as important as that of functionality of parts made
Maritimer
19
Are those scraping marks on the block?
saviour stivala
51
Maritimer wrote:
02 Dec 2018, 21:11
If you are referring to those ‘DOT’ like marks/indentations on the flat surface of lower of Delage block and sump castings, no they are not scraping marks. Scraping is only carried out on two mating surfaces that are intended to work together.
617
saviour stivala wrote:
02 Dec 2018, 22:50
Maritimer wrote:
02 Dec 2018, 21:11
engine-turning is/was the term in UK English
a decorative finish made by a small rotary mop loaded with abrasive then re-positioned accurately and repeated in a pattern
presumably cheaper than smoothing and polishing castings
some current antiques 'experts' wrongly describe a similar embossed finish on sheet metal as engine-turned
a modified Delage won often in the 1930s 1500 cc class driven by Richard Seaman (costing £2 million in today's money)
getting him a job driving the W125 etc
post WW2 different modified Delage with a 2 stage ERA engine did well in F1
Big Tea
When ever I see the old style race car, the brakes, tyres steering, it reminds mo of a verse from Kiplin.
"But remember, please, the Law by which we live,
We are not built to comprehend a lie,
We can neither love nor pity nor forgive.
If you make a slip in handling us you die! "
Power and beauty, but one slip and.."Our touch can alter all created things,"
(The Secret of the Machines
BY RUDYARD KIPLING)
Also, suprised to see the constant depression carb, I thought it was too early for that.
dren
226
That Delage is quite impressive! Thanks SS for these and more to come.
Honda!
hollus
1932 Alfa Romeo tipo B 2.7-litre eight
1932 Alfa Romeo tipo B 2.7-litre eight: Single aluminum monobloc casting that unified 2 cylinder heads and 2 4-cylinder blocks that extended upwards to carry the twin overhead camshafts. Resting on a common aluminum crankcase, the cylinder walls were formed by dry steel liners which were inserted from the bottom and shrunk into position and clamped by a small flange against the top of the crankcase.
The crankshaft was made as 2 separate 4 cylinder parts united at the center by a pair of gears, one of the gears drove the camshafts through a gear train while the other drove the supercharger and the oil and water pumps. This center type of drive eliminated torsional vibrations.
2 valves per cylinder were equally inclined at 52 degrees from vertical. 18mm plugs were used placed vertically at the center of the chamber and firing through masking aperture. All valves seated directly on the head. 3 springs closed each valve, a screwed cap onto the valve stem with matching serrations on the spring retainer was screwed in or out for valve adjustment.
A central gear were bolted to separate camshafts for each bank each cam running on 3 plain bearings. The central drive train spur gears ran on ball bearings. From the left side of the block a gear train from the crank center drove a pair of 2-lobe roots type superchargers, one for each set of 4 cylinders, each had a rotor 90mm long and a capacity of 1350cc. Driven at 1.45 times engine speed (the ratio could be changed) the 2 superchargers produced a boost pressure of 11psi. Underneath each blower was its own 42mm updraught Weber carburetor (BS42).
Aluminum pistons with 3 compression and 1 oil ring above the gudgeon pin and 1 oil ring bellow it were used. A steel 2 bolt cap con-rod with 18mm gudgeon in a bronze bush was used. 10 babbit main bearings with caps tightened by 2 studs against the bottom of the magnesium crankcase which was split at crank centerline. Dry sump by scavenge and pressure gear oil pumps.
Specifications
Cylinders l8.
Bore 65mm.
Stroke 100mm.
Stroke/bore ratio 1.54:1.
Capacity 2655cc.
Compression ratio 6.5:1.
Con-rod length 216mm.
Rod/crank radius ratio 4.3:1.
Main journal 61mm.
Rod journal 52mm.
Inlet valve 39mm.
Exhaust valve 39mm.
Inlet opens 20 degrees BTDC.
Inlet closes 50 degrees ABDC.
Exhaust opens 50 degrees BBDC.
Exhaust closes 20 degrees ATDC.
Inlet pressure 1.76 Atm.
Peak power 215 BHP@5600 RPM.
Piston speed corrected 14.8 m/s.
Peak torque 285nm @3750RPM.
Peak bmep 196psi.
BHP per litre 81 BHP/Litre.
Rivals, not enemies.
hollus
Some links about the 1932 Alfa Romeo tipo B 2.7-litre eight.
I am not 100% about the images for this one, there seem to be slightly different variants around, so please correct any errors below or by PM!
https://www.roadandtrack.com/car-cultur ... 4c-spider/
https://silodrome.com/alfa-romeo-p3/
saviour stivala
51
hollus wrote:
03 Dec 2018, 19:38
https://upload.wikimedia.org/wikipedia/ ... a_P3_B.jpg
https://hips.hearstapps.com/roa.h-cdn.c ... size=768:*
https://silodrome.com/wp-content/upload ... 40x494.jpg
There was different variants of both cars and engine as both are developed over years/seasons. The excellent picture/photo is in my opinion of a 1931 Jano’s back than introduced new creation the 8C 2300, It had the same basic straight eight engine of the 1932 tipo B which was enlarged to 2.7-litres. The engine is clearly and Easley recognized by its distinguished central crankshaft drive dividing the engine into 2 four cylinder blocks.
Maritimer
19
02 Dec 2018, 22:50
Maritimer wrote:
02 Dec 2018, 21:11
Scraping is done for decorative purposes all the time
saviour stivala
51
I know that some people looks at a scraped working surface they have scraped with pride and as a sign of beauty in their workmanship. I know because I done and still do some scraping myself. Some might even scrape a non-functional surface to show-off. But back to that fine photo showing one of the finest and most beautiful engines ever made, the 1927 Delage 15-S-8 1.5-litre eight, what you see on the lower and upper crankcase are not scraping marks.
hollus
1936 Auto Union C-type 6 litre V16
1936 Auto Union C-type 6 litre V16. Used from 1934 to 1937 was an amazing and magnificent achievement. Among the most brilliant, the only 16-cylinder ever to achieve consistent success. By Dr.Eng. Ferdinand Porsche and designer Josef Kales. High power through high torque at low crank speeds.
Lower structural stresses allowed the block and crankcase to be cast in one piece in thin wall high-silicon-alloy aluminum. Inserted were forged chrome-alloy-steel cylinder liners exposed to cooling water. Detachable cylinder heads were used, studs retaining the heads were long, extending well down into the block. Cylinder banks at 45 degrees and valves disposed at 90 degrees to each other, single 18mm spark-plug was used.
A masterful arrangement of valve gear and induction, only one single central overhead camshaft was used, rotating in 9 bearings and containing 32 lobes, opened the inlet valves directly through fingers on parallel shafts, the outboard exhaust valves were opened remotely through finger followers which operated rocker arms at the exhaust valves through horizontal push-rods.
The major accessory drives were at rear of engine, taken from crank between ninth and tenth main bearings. Bevel gear drive vertical shaft from crankshaft drove the camshaft. Side bevel gears from this shaft drove the twin eight cylinder Bosch magnetos. Above them a multi-disc clutch pack drove the primary lobe of a vertical roots supercharger delivering 2.8 litres per revolution rotating more than twice engine speed with a boost of 9psi.
Blower was offset to left so its output could be ducted around the vertical shaft to the center inlet passage. With surpassing genius it was arranged for the inner surface of the heads covered by aluminum casting of cam-housing to enclose a volume that served as inlet manifold.
The bottom of crankcase was at an angle as viewed from the side, at the rear it reached all the way down to the bottom of clutch/flywheel assemble. At the rear twin gear-type oil pump rotating at 5 times engine speed, 1 was scavenge the other a pressure pump.
The exhaust manifold collected 2 cylinders at a time (4 exhaust pipes on each side). Forged chrome-nickel-steel crankshaft in tin-bronze bearings shells, similar bearings for con-rods, an external tube from big-end to gudgeon pin carried oil to pin. Pins retained by aluminum buttons. A Solex 2 float chambers twin-throat 48mm carburetor was used.
Specifications:
Cylinders V16.
Bore 75mm.
Stroke 85mm.
Stroke/bore ratio 1.13:1.
Capacity 6006cc.
Compression ratio 9.2:1.
Con-rod length 168mm.
Rod/crank radius ratio 4:1.
Main journal 70mm.
Rod journal 68mm.
Inlet valve 35mm.
Exhaust valve 32mm.
Inlet pressure 1.97Atm.
Peak power 520BHP@5000rpm.
Piston speed corrected 13.1m/s.
Peak torque 854Nm@2500RPM.
Peak bmep 260psi.
BHP/litre 86.6BHP/litre.
hollus
hollus
1937 Austin Seven 744cc four
The car nicknamed “A big car in miniature”. The engine: T.Murray Jamieson previously of supercharger makers Villiers who had a dream of an engine rotating at 12-14k RPM was instructed to design and build the best possible 750cc race engine.
A 4 cylinder in line with inverted-cup-type tappets of 53.3mm diameter, drilled around its skirt for lightness had a large coil spring beneath its periphery to keep the tappet in contact with cam-lobe, the lobes were 2 inches wide. The valve itself was seated by 2 coil springs with the combined force of the 3 springs at lift of 500lbs. The same size 2 valves per cylinder were used. They were equally inclined at included angle of 100 degrees from center line seating on inserts of Monel metal in an RR50 aluminum cylinder head.
The block/crankcase also of RR50 aluminum extended to the bottom of the engine. A cast finned sump for dry-sump oiling system closed the bottom.
Accessories were driven from rear of engine, gears out of each side with shafts going forward, the left drove a large water pump at half engine speed, a skew gear on the pump shaft was the access point for starting crank inserted at the side. The shaft on the right side drove the 12k RPM tachometer and also a stake of oil pumps. A scavenge pump at bottom and above a 100 psi pressure pump for the bottom end, also a 10psi pump oiling the valve gear, the shaft also drove a magneto.
The gear train continued to top to drive the camshafts each of which rotated in 3 bearings. Tapped from the rear of the gear train was a drive to a roots type supercharger driven at 1.5 times engine speed.
The supercharger was sized to provide a boost of 22psi; its output was supplied through a finned cast light-alloy pipe with a blow-off valve on it, to a finned manifold mated with the head porting.
A single SU carburetor was used. After piston-crown failures were encountered a 2nd float bowl was added to the carburetor.
The machined from solid 3 main bearing crankshaft had a plain lead-bronze center main, while the other 2 mains were roller bearings. Rod bearings were plain white-metal bearings. An oil feed to the bearings through the nose of the crank was used. 2 bolt big-end caps were used.
Slipper-type pistons with 2 compression rings and 1 oil ring were used. A wet nitride steel cylinder liner hung free at bottom with rubber seal to block. 4 studs per cylinder tied the head to the block.
Specifications:
Cylinders l4.
Bore 60.3mm.
Stroke 65.1mm. Stroke/bore ratio 1.08:1.
Capacity 744cc.
Con-rod length 127mm.
Rod/crank radius ratio 3.9:1.
Main bearing journal 63.5mm.
Rod journal 44.5mm.
Inlet valve 38.1mm.
Exhaust valve 38.1mm.
Inlet pressure 2.5Atm.
Engine weight 118kg.
Peak power 115BHP@7600RPM.
Piston speed corrected 15.6m/s.
BHP per litre 155.9 BHP per litre.
Engine weight per BHP 1.01kg per BHP.
