Scuderia Ferrari SF90
Nano4k
Re: Scuderia Ferrari SF90
cooling through the shark fin.
JPBD1990
JPBD1990
47
Nano4k wrote:
15 Feb 2019, 12:56
More information?
Not being rude I just don’t know what you mean and I’m interested
LM10
LM10
120
JPBD1990 wrote:
15 Feb 2019, 12:57
Nano4k wrote:
15 Feb 2019, 12:56
More information?
I think he means the slot just above the wastegate pipes. Seen on the picture of the rear of the car.
TimmTurbo
TimmTurbo
JPBD1990 wrote:
15 Feb 2019, 12:57
Nano4k wrote:
15 Feb 2019, 12:56
More information?
You can see a hollow section above the two pipes (Wastegate)
Nano4k
JPBD1990 wrote:
15 Feb 2019, 12:57
Nano4k wrote:
15 Feb 2019, 12:56
More information?
just an outlet in the sharc fin like Mercedes had. maybe using a "chimney" effect
Fede90
Fede90
a lot of wing profiles, i count 4. One more than last year and a different design
SiLo
134
It looks like they have made the upper part of the air intake and body of the car smaller but moved things into the sidepods. I'm assuming there will be a lot of differences in testing as there aren't as many changes as I expected.
Felipe Baby!
paddyf1
paddyf1
To my eye it looks like the engine cover is very tightly packaged, behind the air intake, the size of the shark fin gives it away a little, perhaps they are putting more back into the side pods to free up space above the engine, to help get as much air to the rear wing as possible, backed up also by the smaller air intake.
Mamba
Mamba
I don't expect much change come testing. We say we'll see new parts every year and then nothing happens. I think most of their work clearly happened under the hood since the Car seems under developed in terms of small details compared to SF-71! Strange...
pentaquark
I think, come Monday, we'll see the new rims. Especially the rear ones which will feature a Mercedes like design. Since the front brake ducts are a bit larger and have diffierent compartments I would also say we're going to see new front rims aswell.
JPBD1990
JPBD1990
47
Mamba wrote:
15 Feb 2019, 13:16
You can barely make out any small details, so big call to call it underdeveloped.
Try and remain unencumbered by the weight of expectation. The only reason we were expecting “more” is because 2017/18 saw them usher in an entirely new concept (high sidepods). We don’t know the half of what’s going on yet.
Hydraulic rear suspension should see a solid improvement for slow speed, and we already ruled the roost in high speed. It didn’t need to be a revolution.
You can’t compare it to McLaren and say we did nothing. Of course, we didn’t radically change concepts, but we weren’t almost dead last in 2018 so... why would ya?
CriXus
CriXus
95
“The reasonable man adapts himself to the world: the unreasonable one persists in trying to adapt the world to himself. Therefore all progress depends on the unreasonable man.” - George Bernard Shaw
Zynerji
109
Oddly, id be interested in seeing the 2017/2019 comparison instead...
motobaleno
maybe we are underestimating the FW question: it is a far different concept from RB and Merc.
I would say that is not likely that both are delivring the same performance...which one will be the "right" one?
