Scuderia Ferrari SF90
aral
aral
26
Re: Scuderia Ferrari SF90
wuzak wrote:
15 Feb 2019, 18:06
aral wrote:
15 Feb 2019, 17:39
wuzak wrote:
15 Feb 2019, 16:45
Is it me, or does the wheelbase look a touch shorter?
[/qu
Based on what?
Sadly, you can tell nothing from two random photos as there is no reference plane. A different lens used can alter the perceived size of the car. Further the changed appearance such as new front wing position can make a big difference.
Currently there is no information as to wheelbase of the car, so any view cannot be substantiated.
bit1817
bit1817
Would maximizing the free air to the wing lead to lesser wing angles to generate the same downforce level?
ferkan
ferkan
31
Why would anyone think Ferrari trimmed upper parts of engine cover and airbox because they cant seal diffuser? Such a jump to conclusion given that sidepods and cokebottle area are still very narrow and tight.
dans79
267
LM10 wrote:
15 Feb 2019, 21:12
Wouldn’t going such a radical way by maximizing airflow to RW because of the disability of sealing the floor and diffuser mean that they wouldn’t be able to do any upgrades at all on floor and diffuser? I think they would have even changed the concept to generate floor and diffuser downforce instead of compensating it in such a way.
I wouldn't call it radical, just a different path. Maybe they couldn't generate the numbers they wanted with the floor/diffuser, or maybe they needed more time to fine tune it, and the rear wing was a safe bet for early in the season. No one outside of Ferrari knows for sure.
206 177 106 104 9 9 7
SAEED
SAEED
Redragon wrote:
15 Feb 2019, 20:20
What feels odd is after last years mirrors which were at the presentation and Redbull copying the concept this year they don't have them on this year presentation. So they might have something even more innovative on that area?
This year's mirrors are a lot more outboard.
ferkan
ferkan
31
dans79 wrote:
15 Feb 2019, 21:48
LM10 wrote:
15 Feb 2019, 21:12
Or they thought that is the area they can tiddy up given that its been noticably trimmed, while coke bottle and sidepod area remained very narrow and tight as last season?
Manfer
Manfer
Having a high energy flow turned up by the rear wing is beneficial for the perfomance of the central region of the diffuser as compared to a disturbed flow hitting the rear wing. The whole rear end is aerodynamically connected, which is why they have bought in a twin set T wings. Every little bit helps connect the diffuser upwash to the rear wing upwash.
Gearbox 'tunnel' still there?
roon
roon
412
miguelalvesreis wrote:
15 Feb 2019, 18:00
Why is this upper arm so thick? Any thoughts?https://uploads.tapatalk-cdn.com/201902 ... 80e595.jpg
Enviado do meu SM-T820 através do Tapatalk
This arm likely improves the rigidity of the upper rear wing flap. When the DRS active, this arm provides the upper flap a fourth point of contact to the car. Previously there were only three points of contact when DRS was active: the hinges on either end of the flap, and the DRS pullrod (which does not carry vertical loads). Compare to last year's car:
Just_a_fan wrote:
15 Feb 2019, 14:47
dans79
267
Scarb's opinion!
Somewhat surprising seeing Ferrari putting more focus into a streamlined airbox than the sidepods.
Then again percentage of downforce from the RW does get higher with the new regulations.
Tzk
Tzk
36
If you can generate downforce on the rearwing as efficient as on the diffusor, i‘d choose the wing. This will give you way better drs efficiency, as the flap height generates a even bigger drs effect than last year.
This could give ferrari an advantage over merc and rb, when the ferrari is the overtaking car.
dans79
267
Tzk wrote:
15 Feb 2019, 23:05
I haven't crunched numbers in a long time, but if memory serves rear wing DF comes with substantially more drag.
Tzk
Tzk
36
You’re probably right ;)
LM10
LM10
127
dans79 wrote:
15 Feb 2019, 23:10
Tzk wrote:
15 Feb 2019, 23:05
Wouldn't a big airbox be draggy as well?
Sempre Forza Ferrari
