Scuderia Ferrari SF90
wuzak
wuzak
532
Re: Scuderia Ferrari SF90
I wonder if it would be of any benefit to extract air from the cockpit in that location, to try to control the turbulence in the cockpit and surrounds.
wickedz50
wickedz50
MtthsMlw wrote:
20 Feb 2019, 22:49
timbo wrote:
20 Feb 2019, 21:18
Wonder why they wrapped the test a bit early.
Hope there were no glitches in the car.
They simply finished what they wanted to do earlier.
Its quite tiring for any driver to grind the whole day out doing 150plus laps. Even though they are super fit it is still too much to expect. Ferrari have not split the session between 2 drivers like the other teams. In that case its possible for each driver to do 80plus laps each session. 30-40 laps gap to other teams each day of testing does in no way effect or change where they will ultimately stand in 2019 championship.
If there was any issue there are Sky-spies all around the paddock to report the same,
Chuckjr
The SF90 looks anchored to the tarmac. No wiggles or unexpected's anywhere on the LeClerc clip. Certainly Ferrari is not pushing as nobody is pushing yet, but to have it this steady right out of the box is a great sign. I've seen many years when a team is wiggling bad out of the box. This car has none of that. It makes it all the more encouraging to see their reliability so strong with a steady car. All good signs.
Watching F1 since 1986.
F1NAC
173
Smoke is still there
OO7
OO7
171
Ferrari have definitely found something that allows them to run an extremely low front ride height.
TimmTurbo
TimmTurbo
Blaze1 wrote:
21 Feb 2019, 10:53
Of what rumors say it has something to do with their hydraulic controlled rear suspension. Huge AoA (Rake). The car is tilting massively when the areodynamic load is coming off during breaking in turn 1 in Barcelona.
Mr.G
34
TimmTurbo wrote:
21 Feb 2019, 11:39
Blaze1 wrote:
21 Feb 2019, 10:53
Any slow motion gif?
Kalsi
Kalsi
31
Mr.G wrote:
21 Feb 2019, 12:08
Couldn't find or make a slowmo out of this but... it's still pretty visible
TimmTurbo
TimmTurbo
Thanks Kalsi, seems to be at least 80 - 100 mm lift. Obviously there is some weight transfer hence movement in all of the cars but it is noticeably different on the SF90.
The AoA of the Front wing is therefore bigger in corners which is beneficial for down force and its lower to the ground which supposeldy adds DF as well. No Areo guy though
It's not that much, around 40-50mm rear ride height increase at most. However, definitely more than usual.
Kalsi wrote:
21 Feb 2019, 12:53
Mr.G wrote:
21 Feb 2019, 12:08
https://media.giphy.com/media/1yTgcCeZM ... source.gif
https://media.giphy.com/media/fLv9nQbZA ... source.gif
Looks "programmed in" indeed, huge change in a short time and then it stops diving.
AMG.Tzan
44
It doesn't look much for Ferrari but Red Bull and Mercedes seem like they are not moving at all under braking!
Seanspeed
Seanspeed
AMG.Tzan wrote:
21 Feb 2019, 14:09
Here is the Red Bull, just for comparison. It is a very stark difference.
AMG.Tzan
44
Seanspeed wrote:
21 Feb 2019, 14:17
AMG.Tzan wrote:
21 Feb 2019, 14:09
http://i.picpar.com/2zhd.gif
That's what I was talking about! That exact moment I saw earlier today on F1 TV!
Ferrari must be running soft rear springs or have found a way to do that without losing any balance...although I think that the SF90 is just a great car and performs better under Barcelona's chilly conditions and has no special aero or mechanical trick!
cplchanb
cplchanb
Time for a technical clarification?? :wink:
