Red Bull RB15
gandharva
252
Re: Red Bull RB15
Probably some aero device to check break duct airflow.
anthonyfa18
anthonyfa18
27
Re: Red Bull RB15
HERE IS BETTER SHOT
zoro_f1
-2
Re: Red Bull RB15
Image “The force can have a strong influence on the weak-minded”: [Obi Wan Kenobi]
Coefficient
Coefficient
Re: Red Bull RB15
anthonyfa18 wrote:
21 Feb 2019, 16:48
HERE IS BETTER SHOT
https://images.scribblelive.com/2019/2/ ... 54_800.jpg
Diffusor flex?
Re: Red Bull RB15
Here's another photo
Jolle
Jolle
132
Re: Red Bull RB15
Coefficient wrote:
21 Feb 2019, 16:57
anthonyfa18 wrote:
21 Feb 2019, 16:48
HERE IS BETTER SHOT
Diffusor flex?
not anymore :P
yener
Re: Red Bull RB15
Wow, those are used to make the rear stiffer. So it means the rear is realy twitchy.
how many laps did he used this?
"Life is about passions - Thank you for sharing mine" MSC
santos
santos
Re: Red Bull RB15
Could this be something related with the rumor of vibrations? Perhaps they are trying to make the rear more rigid.
Jolle
Jolle
132
Re: Red Bull RB15
The cables to minimise flex of the rear are, compared to the other teams much more near the center line of the car. Maybe just a tad too much on the edge. easy fix.
Sieper
73
Re: Red Bull RB15
These look like rear suspension pullrods used as a temporarily fastener to indeed make the diffusor more solid. Perhaps they want to test if that impacts the rear grip / diffusor effectiveness in real life conditions if they go for making it more solid.
39
Re: Red Bull RB15
Could they be used to "tune" the diffuser? What I mean is bend or flatten the profile of the diffuser. Although you would probably want paint on the rear to see what the air is doing.
Re: Red Bull RB15
They could have load sensors in them and just be trying to see what load they're getting in the outer part with the rear wing pushing down.
Re: Red Bull RB15
I thought that but I've had a good look at all the photo's and can't spot any sensor wires, they look just like a piece of ally bar with two rose joints slapped in either end. Maybe they're having some floor flutter/vibration and looking to see if stiffening it helps.
Re: Red Bull RB15
Godius wrote:
13 Feb 2019, 14:14
Have not seen a s-duct outlet spoiler like this before.
It was used on the RB-8. It is not an outlet, but an air-dam to make a smooth ramp of air infront of the cock-pit.
☄️ Myth of the five suns. ☄️
LxVxFxHxN
Re: Red Bull RB15
What? It very much is an outlet, it's as clear as day to see from the rear.
