Red Bull RB15
muramasa
muramasa
58
Re: Red Bull RB15
santos wrote:
21 Feb 2019, 17:06
Could this be something related with the rumor of vibrations? Perhaps they are trying to make the rear more rigid.
Jeez once you learn one thing you apply it to everything, so how about those bargeboards, side wings and rear wings flying off on the other cars, are they due to vibration as well perhaps? It's just that RB15's diffuser or side connection is too fragile requiring re-design that's it.
PhillipM wrote:
21 Feb 2019, 20:24
What? It very much is an outlet, it's as clear as day to see from the rear.
Yeah...do some people not explore and look at other pics but only judge from one studio pic? On that studio pic it's shadow cast over it which makes it look like opening but it's not, opening is on the rear and also on some day they ran without the duct but with bulged cover.
Re: Red Bull RB15
muramasa wrote:
21 Feb 2019, 20:47
santos wrote:
21 Feb 2019, 17:06
Quite probably, yes, it's generally vibrations that cause peak loadings and fatigue :wink:
santos
santos
Re: Red Bull RB15
muramasa wrote:
21 Feb 2019, 20:47
santos wrote:
21 Feb 2019, 17:06
PhillipM wrote:
21 Feb 2019, 20:24
Easy... i'm just asking. If i make a question it's because i don't know.
Capharol
Capharol
21
Re: Red Bull RB15
santos wrote:
21 Feb 2019, 22:10
muramasa wrote:
21 Feb 2019, 20:47
santos wrote:
21 Feb 2019, 17:06
PhillipM wrote:
21 Feb 2019, 20:24
don't get yourself to mixed up about it santos, he reacted the same way to me
muramasa is a selfpronounced Honda-guru .... don't ask questions or don't think different..... hell don't even breath when he is online
RonDennis
RonDennis
Re: Red Bull RB15
santos wrote:
21 Feb 2019, 22:10
muramasa wrote:
21 Feb 2019, 20:47
santos wrote:
21 Feb 2019, 17:06
PhillipM wrote:
21 Feb 2019, 20:24
According to Motorsport Italia they tried it because of the vibrations of the Honda engine, which seems likely if you look at the places it's connected to.
https://it.motorsport.com/f1/news/red-b ... a/4341919/
bigblue
Re: Red Bull RB15
RonDennis wrote:
22 Feb 2019, 02:14
Umm, it's connected to the exhaust (of the engine) ? Why would you connect the diffuser to a (supposedly) vibrating engine ?
foneFanatiq
Re: Red Bull RB15
bigblue wrote:
22 Feb 2019, 02:18
RonDennis wrote:
22 Feb 2019, 02:14
:lol: Very. Very good point
Manfer
Manfer
Re: Red Bull RB15
The rods connect the base of the central pillar holding the rear wing to the base mounts of the wing. This could have been done to restrict movement of the rear wing or they wanted to test something or It might have also been that these parts would have gone over the design fatigue cycles and might have been on its last legs. A quick fix solution to reinforce the wing till the end of testing.
roon
roon
412
Re: Red Bull RB15
PhillipM wrote:
21 Feb 2019, 17:42
I thought that but I've had a good look at all the photo's and can't spot any sensor wires, they look just like a piece of ally bar with two rose joints slapped in either end. Maybe they're having some floor flutter/vibration and looking to see if stiffening it helps.
I agree. Alternatively, perhaps there was a concern about excessive deflection.
Re: Red Bull RB15
Perhaps an attempt to dissipate the resonance of the exhaust into the floor. They didn't run it in the end, will be interesting to see what they come up with.
Zynerji
112
Re: Red Bull RB15
godlameroso wrote:
22 Feb 2019, 04:33
It ran on track. Will Buxton pointed it out during testing.
39
Re: Red Bull RB15
I doubt very much it is to do with PU vibrations, other than maybe a resonance in the chassis(even that seems unlikely) TR was going faster than RB and had none of these so called PU vibration issues. Are we saying the TR chassis is better than RBs because with the PU vibrating all over the place they obviously cant turn up the power?
Not to mention no team was running full power. RB ran with the supports for a bit and then removed them from what I read. Maybe they were checking wing flex with and with out it.
Note I'm not saying there aren't vibration issues, there could be. I just dont think we see them at this test.
NathanOlder
Re: Red Bull RB15
They were definitely running with those supports for a good few hours.
GoLandoGo
Lewis v2.0
King George has arrived.
Re: Red Bull RB15
Struts are there to stiffen the diffuser, excessive deflection is known to cause (sometimes serious) performance drop. It has nothing to do with stiffening rear wing, exhaust or anything else, those kinds of struts would be placed on different locations.
henry
324
Re: Red Bull RB15
The struts connect the diffuser top surface to the gearbox via the central rear wing support. The rear wing support forks around the exhaust.
So the struts connect the diffuser to the chassis at additional points compared with how it was before. It seems very likely this is for stiffening, whether against inertial loads or aerodynamic loads only Red Bull know.
