Mansell89
Mansell89
Huge congratulations to Honda on their first podium back in the hybrid era- tremendous job guys!
gandharva
252
https://twitter.com/HondaRacingF1/statu ... 9892944896
Decent start. I wonder how much they actually found over the winter.
ispano6
164
gandharva wrote:
17 Mar 2019, 11:18
Tanabe finally got a hair cut! Looking sharp and invigorated than before!
anthonyfa18
anthonyfa18
27
Honda RA619H
carisi2k
29
Is it a bend or is it just an open cup allowing air downwards. In any case I think it is applied better then the Mclaren solution used to be.
GhostF1
GhostF1
112
carisi2k wrote:
18 Mar 2019, 05:49
Based on the light reflection on the pipe, it looks like it flares back out, similar to the RA618 in the STR last year. the RA617 was strangled by that McL design. Doubt that would return.
Bandit1216
21
Maybe covered before, but what is the cooler on the backbone of the engine?
But just suppose it weren't hypothetical.
carisi2k
29
In any case it does look like a special piece of packaging and unfortunately only the Dutchman will be able to take advantage of it going forward. Quite an amazing bit of kit and I think Bahrain will be much closer then Melbourne.
vidya31
vidya31
Excellent thread..!!!
vehicledynamics
vehicledynamics
Very interesting topic guys!
vehicledynamics
vehicledynamics
Very interesting topic guys!By the way, could someone put here some data about speed traps by sectors and Max Speeds between different cars and engines? It would be nice to see it! :D
garygph
garygph
vehicledynamics wrote:
18 Mar 2019, 14:11
Not sure if you are looking for race or practice data but anyway I am sure if you just read and enjoy the threads you will find what you are looking for. All done nicely for us :D already.
munudeges
munudeges
-14
gandharva wrote:
17 Mar 2019, 11:18
They know what the score is, and their language says all the right things.
foneFanatiq
Does anyone know what components can be changed out on modern PUs in-between races? Like what wear parts get replaced or freshened up before the next race?
Sieper
73
Interesting question, I would like to learn the answer. My expectation (but like Manuel, I know nothing, although unlike him I am not from Barcelona (and my colleagues actually from Barcelona do know a lot) is nothing, the whole PU should be kept closed. maybe some hoses and connections outside.
