McLaren MCL34
ThePapayaJaguar
ThePapayaJaguar
Re: McLaren MCL34
Marc.W wrote:
10 Apr 2019, 12:17
ThePapayaJaguar wrote:
10 Apr 2019, 10:38
Even cooler video! Looks like Carlos lost those six one-hundredths at the last corner! Had a bit of oversteer there. The car does look very fast in the straights. The car looks very promising!
https://www.youtube.com/watch?v=9ptvx7qqCr8
One thing I notice is how early Carlos is able to go full throttle compared to Max, really good traction
Yeah, Carlos said that the rear end grip is good, but the car lacks a bit of front end grip. Hopefully, we'll see some small updates that will help with front end grip in China as it is a front downforce heavy track.
_cerber1
300
Re: McLaren MCL34
Chicane
Chicane
Re: McLaren MCL34
China is a low-medium downforce track under these aero regulations. The rear wing may change for Barcelona which is a medium-high downforce track.
Mclaren are hunting for front downforce not just from front wing but also from speeding up the the air flow under the floor.
Quickshifter
_cerber1
300
Re: McLaren MCL34
ThePapayaJaguar
ThePapayaJaguar
Re: McLaren MCL34
M840TR wrote:
10 Apr 2019, 12:17
10 Apr 2019, 10:38
Also, faster than the Redbull on the straights.
Noticed that as well! Encouraging signs coming from McLaren!
_cerber1
300
Re: McLaren MCL34
M840TR
M840TR
315
Re: McLaren MCL34
f1rules wrote:
10 Apr 2019, 21:46
thats a nice comparison thanks , i still think mclarens maine plane and raised outer sections differ from the rest, it starts earlier which costs front df, im not saing its wrong, its just an observation
https://pbs.twimg.com/media/D30Oy7WWsAIsR_u.png
Secondly, the front wing operates in ‘ground effect’. This is the phenomenon whereby as the proximity between ground and the front wing diminishes, an enhancement in downforce level is observed at an exponential rate (that is until the wing ‘stalls’ – more on this in the next article). Ground effect increases the efficiency of downforce production and is partly why the latest trend is to run the car at extreme rake (i.e low front ride height and high rear ride height means the front wing sits closer to the ground).
Ground effect has nothing to do with it. Mclaren already runs the fw low to the ground for ground effect and better diffuser performance via high rake. The outboard section of mainplane is raised to let air into the two strakes underneath, which generate outwash.
M840TR
M840TR
315
Re: McLaren MCL34
f1rules wrote:
11 Apr 2019, 05:10
yeah they will probably continue with this for the next two gps, maybe even wait til monaco with a high df version
Next gp is Baku which will feature ultra low-df rear wing.
M840TR
M840TR
315
Re: McLaren MCL34
Chicane wrote:
11 Apr 2019, 06:56
Floor downforce helps rear-end traction. The FW is the only part of the car - since there's no S-duct - that generates upwash for the front.
f1rules
f1rules
634
Re: McLaren MCL34
AMUS
Ground Effect
Re: McLaren MCL34
M840TR wrote:
11 Apr 2019, 11:53
Chicane wrote:
11 Apr 2019, 06:56
Why wouldn't McLaren make use of an S duct though? Looks like it wasn't there last year either, if I'm not mistaken.
_cerber1
300
Re: McLaren MCL34
New?
f1rules
f1rules
634
Re: McLaren MCL34
no, used from start
M840TR
M840TR
315
Re: McLaren MCL34
Ground Effect wrote:
11 Apr 2019, 12:48
M840TR wrote:
11 Apr 2019, 11:53
Chicane wrote:
11 Apr 2019, 06:56
They use the duct to power the cape.
Emag
Emag
137
Re: McLaren MCL34
Is there a slot here? If so, where would the air come out.
Developer of F1InsightsHub
