Scuderia Ferrari SF90
ScrewCaptain27
577
Re: Scuderia Ferrari SF90
AMuS
- Serj Tankian
pantherxxx
I still feel like even if the Ferrari SF90 is the fastest car on the grid, if they can't fix their reliability problems, they won't win the championship.
Webber2011
pantherxxx wrote:
12 Apr 2019, 10:27
Again 😉
f300v10
185
Ferrari fitted the 'spoonish' rear wing seen at the Bahrain test on Seb's car in FP2:
f1jcw
If this is true, it is. Earthquake
Interesting from Rosberg:
"I talked to the Ferrari guys and they said to me that they have positioned the car wrong regarding the aerodynamics. They are driving with less aero and they don't have an adequate package to put on the car to have more downforce."
Rosberg: "They are working on that. Ferrari will bring a new rear wing soon. But the problem is that the whole car is positioned in that area so it's not easy. Just changing the rear wing might make the car completely inefficient."
https://mobile.twitter.com/Vetteleclerc ... 6446476288
Ringleheim
f1jcw wrote:
13 Apr 2019, 12:51
What does he mean "The whole car is positioned in that area" ???
Does he mean there are many components under the bodywork in the area that needs to be modified, so it would be a packaging nightmare to substantially change the car because you would have to move so many things around or change their design?
Or does he mean something else?
Doesn't sound good!
f1jcw
I presumed that he means the whole aero concept is developed in this way, so to change it they have to change everything
djones
I would read it as the front wing concept and then back from there as the package.
This would fall in line with 'that BBC article' from a month or so ago.
Maybe we will see a spec b at some stage with a traditional front wing. I say spec b as there are probably a LOT of things that need to change to account for that.
Fer.Fan
So far SF-90 seems to have lack of downforce. The car is slow in corners.
Compared to quali 2018 SF-90 was 0,8 sec slower today in quali. I think the hole aerokoncept seems wrong.
Mr.G
34
Or they expected rain which doesn't came and ser it up different...
mika vs michael
-1
Mr.G wrote:
13 Apr 2019, 20:11
Or maybe the SF-90 is not the car they all thought it was during winter testing in Barcelona!
"It is necessary to relax your muscles when you can. Relaxing your brain is fatal." Stirling Moss
I tried this and I had understeer, I tried that and I had oversteer, at the end of the corner I just run out of talent
Mr.G wrote:
13 Apr 2019, 20:11
You wouldn't set the car up with less DF and more straightline speed for rain...
mmred
-3
Fer.Fan wrote:
13 Apr 2019, 19:44
the real difference is just 0,3
there s no wrong aeroconcept
there are just aero good for more downforce and aeros for less
they may have a car good for faster tracks
in the end you win after all the races
the reliability i an issue instead, cause when you are superior like in barhein you have to win
GrandAxe
If Ferrari is going to bring a new rear wing to sort their issues, then they might have to produce even bigger bargeboards than the current huge ones they have to balance front and rear downforce. It would be an interesting car to see.
It would also be interesting to see if BBC's secret aero guy is correct about the low downforce front wing offering few options for development. I know this link has already been posted a thousand times :) :
https://www.bbc.co.uk/sport/formula1/47527705
... But maybe, just maybe, Ferrari is developing an RB/Merc style front wing alongside the new rear wing and we might see an entire change of downforce philosophy mid-season!
