McLaren MCL34
Ground Effect
Re: McLaren MCL34
I'm keen to see what they can come up with in regards to the front wing, can they come up with something clever or innovative? Andy Green of RP had said there's very little wiggle room with the front wings, cause the new rules more or less closed up a lot of potential loopholes. He said the bargeboards is a treasure trove though. So hopefully McLaren will continue to develop that as well.
bm150
bm150
Re: McLaren MCL34
PhillipM wrote:I went on the hunt see if I could find anything about new parts this GP since someone asked and I haven't spoken to a few of the lads for a while - heard nothing bar the above, although in the process it got mentioned that a new floor is being pushed forwards for Spain as they're running on the last spares of the originals now anyway - and they were already tooling up.
No details on what's changed though unless someone else has better contacts to do some digging. :)
Where do you get your Intel from?
Sent from my SM-G975F using Tapatalk
M840TR
M840TR
315
Re: McLaren MCL34
Ground Effect wrote:
21 Apr 2019, 19:55
Nothing but minor iterations especially this early into the season.
Re: McLaren MCL34
M840TR wrote:
22 Apr 2019, 11:32
21 Apr 2019, 19:55
They can do like merc and widen the top front wing piece that is directly in front of the front tire.
An over simplification. If only it was that easy :D
zibby43
zibby43
Re: McLaren MCL34
_cerber1
301
Re: McLaren MCL34
f1rules
f1rules
634
Re: McLaren MCL34
he mentions the rearwing, and they will test two it seem, but it also looks like the front brakeducts are reduced greatly in size also? or maybe it hasnt been mounted
M840TR
M840TR
315
Re: McLaren MCL34
f1rules wrote:
25 Apr 2019, 10:16
Those indeed are new brake ducts. But both the rear wings are huge! They're going to get annihilated on the straights with this.
_cerber1
301
Re: McLaren MCL34
M840TR wrote:
25 Apr 2019, 10:42
Тhose indeed are new brake ducts. But both the rear wings are huge! They're going to get annihilated on the straights with this.
Maybe they are counting on the power of the Renault engine.
Re: McLaren MCL34
M840TR
M840TR
315
Re: McLaren MCL34
The bottom one has no gurney flap, lower AoA and flat edges as opposed to tapered one on the high df version. lower plane seems to be same on both the wings.
Not as low df as some others.
M840TR
M840TR
315
Re: McLaren MCL34
Interesting similarity between teams in that those with a tapered FW (Mclaren, Ferrari, Alfa & Toro Rosso) have large rear wings whereas others - bar williams - have relatively much skinner ones.
_cerber1
301
Re: McLaren MCL34
https://twitter.com/AlbertFabrega/statu ... 0181753856
From this angle, the wing is very small, especially since the lower shelf lies in the horizon.
Re: McLaren MCL34
The area between the Swan Necks look "lifted" or higher than on the old RW...
M840TR
M840TR
315
Re: McLaren MCL34
mclaren111 wrote:
25 Apr 2019, 14:37
What on Earth is "the Swan Necks"?
