Engine technology free-for-all
SmallSoldier
473
Re: Engine technology free-for-all
Zynerji wrote:Single scroll turbo? Surprising...
Not really if the application is for an engine that will always be in the upper rev range and using anti-lag... Twin Scroll helps spool, which isn’t an issue for a race car... For a street car, twin scroll is better
SmallSoldier
473
Another reason to go with single scroll is to be able to use a V-Band... Twin Scroll turbo flanges (with 4 fastening points) run a risk of blowing turbo gaskets because of separation... The vibration and the turbo position (bottom mount) increases that risk
J.A.W.
109
Good shots of the DTM Audi, ta roon.
Those aggressive cam profiles remind me of Ducati 'bump-sticks', I wonder if any 'cross-pollination' occurred.
Holm86
244
Point of twin scroll housings is to even out exhaust pulses better right??
I guess they use the long tube headers for that application in this instance?
Zynerji
110
I thought the real point of twin scroll was that you delivered more torque through the lower/ mid RPM range.
I guess it doesn't matter if you are just way up in the RPM band the entire time.
loner
16
iam no engineer but could such material be used in engines ?!! which part exactly ?!!
Fan, a top researcher in high-temperature-resistant materials, said the composite could be used in various devices, from engines to space rockets and nuclear reactors.
China Develops Groundbreaking Heat-Resistant Material For Hypersonic Weapon
https://sg.news.yahoo.com/could-materia ... 46146.html
para bellum.
Bill
If talking f1 perhaps no because rules are incredibly restrictive engine should be made of aluminum exotic materials like mmc are not allowed
loner
16
well generally but thnx any way...
para bellum.
vorticism
323
𓄀
johnny comelately
110
vorticism
323
𓄀
Zynerji
110
loner wrote:
05 May 2019, 16:35
Starlite?
vorticism
323
𓄀
vorticism
323
Nissan TB drag engine. Note cooling route.
http://www.speedhunters.com/2023/09/gra ... -restomod/
_________________
𓄀
