i think they took every effort to also raise volumentric efficiency , so bmep , so torque . torque x rpm was the power .Nonserviam85 wrote: ↑Tue May 28, 2019 11:05 amThe main focus actually was to increase rpm and reduce weight, I don’t seem to remember that the compression ratio and volumetric efficiencies to be as crucial back in the day.
i have read carefully honda f1 documents about 3rd era NA f1 engines , a great reading and information ! :
https://www.google.com/url?sa=t&source= ... rBsMWwvAXx
with moving trumpets , airbox design , high pressure fuel nozzles taking away latent heat of the fuel / air mixture by vaporizing , valve and head improvements and much more they battled to make the engine suck in as much air as only possible without turbocharging .
since nevertheless an atmo has physical limits in bmep they - like we discuss here - went more and more in rpm to raise power and with this in my opinion we in the 2000,s saw the most extreme b/s ratios and finest internal mechanical solutions ever introduced in a piston engine .
at this time the spectator was only informed about rpm,s they rev . the design approch and internal dimensions were secret.
i,m still very interested in bore and stroke of the still for me unknown cosworth , renault and ilmor of this time .
