2019 Mclaren F1 Team - Renault
Ground Effect
Ground Effect
Re: 2019 Mclaren F1 Team - Renault
Big Tea wrote:
05 Jun 2019, 18:12
The problem with hoping you gain from rain is that by being just half a lap out from your 'want' it can lose you a lot of time. Tyres will not last any longer, so pit, then 30 seconds later it rains.
Nice gap to following car, rain, car in front goes off and safety car. You lose your buffer etc. Fine for us to want rain to improve the spectacle, but it think it is not wise for the drivers to do a rain dance.
If qualifying or the race starts while it’s raining, then there’s a bit more of a known quantity
Big Tea
Ground Effect wrote:
05 Jun 2019, 19:24
Big Tea wrote:
05 Jun 2019, 18:12
Consistent rain, where the cars have run on wets, if in qualli or race, is a different thing. The order should not change much, other than through bad driving. Where some drivers make a difference is by staying on slicks longer or switching to them first, as button used to. I suspect (not enough data) Max will be the net gain from total rain, while he probably would gain from intermittent rain, I think Hamilton and Bottas would not be far off their game either. Possibly some of the lower placed cars would get an advantage too as it would not be so dependent on total power, just putting it down.
I like mid period unexpected rain, when it shakes things up
BrunoH
BrunoH
for sure there is a big gap chassis wise, but the engine is not up to par. i wold say its more or less 65/70pcent chassis, and the rest is engine. but its my opinion,
ScottR267
ScottR267
https://twitter.com/tgruener/status/113 ... 97761?s=21
Another new sponsor for the team, or have McLaren followed Ferrari and not having the exposure of BAT on the cars? Not seen any reports on the latter however.....
Ground Effect
Ground Effect
ScottR267 wrote:
05 Jun 2019, 22:16
I suspect it’s a one off like the 7-eleven branding in Australia, due to advertising restrictions.
onewingedangel
onewingedangel
Suspect BAT are using their space to promote one of their local retailers. If you can't advertise your product, you may as well advertise where to buy them and build on your relationship with a retail partner.
BrunoH wrote:
05 Jun 2019, 22:02
Well you're wrong.
Maritimer
Maritimer
19
05 Jun 2019, 22:38
ScottR267 wrote:
05 Jun 2019, 22:16
Most likely this. I could be wrong but I dont believe they have 7-Elevens in Quebec, Couche-Tard is our domestic equivalent here in Canada. They own Circle K and a few other service station retailers.
kfrantzios
kfrantzios
46
BrunoH wrote:for sure there is a big gap chassis wise, but the engine is not up to par. i wold say its more or less 65/70pcent chassis, and the rest is engine. but its my opinion,
It's more like 90 % chassis 10 % engine. Plus in race mode all engines are within 3% in terms of power.
Sent from my G8341 using Tapatalk
ScottR267 wrote:
05 Jun 2019, 22:16
Local 7-11. Doubt they will go on beyond Montreal.
BrunoH
BrunoH
diffuser wrote:
06 Jun 2019, 02:51
BrunoH wrote:
05 Jun 2019, 22:02
Well you're wrong.
Well, im not in the engineering room to look at the data, even if they themselves dont know exact how much ( remember with honda? ) so i think its a good portion lacking of engine power that in turn forces a team like Mclaren to run less downforce, and that makes the chassis look worse than it is... its a vicious cycle.
Redbull with the honda engine is doing the same, but they seems to be able to generate more from the car than others and can get away with less wing. But i bet if they had the power mercedes has.. with the same wing angles, redbull wold be champions...
Ground Effect
Ground Effect
BrunoH wrote:
06 Jun 2019, 16:15
diffuser wrote:
06 Jun 2019, 02:51
BrunoH wrote:
05 Jun 2019, 22:02
Well you're wrong.
I don’t think McLaren were forced to run less downforce, it’s a concept and philosophy they’ve gone with. They’ve gone with a low drag concept this year, I believe based on what they suffered last year. I believe the plan is to efficiently add downforce as they develop the car.
BrunoH wrote:
06 Jun 2019, 16:15
diffuser wrote:
06 Jun 2019, 02:51
BrunoH wrote:
05 Jun 2019, 22:02
Well you're wrong.
You don't have to be in the engineering room. Just look at the Monaco Gap. Like I said before, every team has atleast 20% more power than they can use there. They all run as much DF as they can cause, well, they have more power than they can use. That Qualifying Gap is all Chassis and tires. It says it all. Merc has hands down the best Chassis this year. With that GAP, doesn't matter what PU they used, they'd still be behind. Big change from last year where RBR would have been 1 & 2 in Monaco if it wasn't for the "Max" issue.
Andres125sx
diffuser wrote:
06 Jun 2019, 16:35
BrunoH wrote:
06 Jun 2019, 16:15
diffuser wrote:
06 Jun 2019, 02:51
Well you're wrong.
Wow what a bold statement for someone who think he knows everything and anyone disagreing is wrong #-o
If my memory serves me, Monaco is around 30% full throttle, the lowest on the calendar, but that´s far from meaning they have more power than they can use. It actually means in one third of the track they could use more power. Fact.
But even in the rest of the track, PUs can make a difference too, even if not at full throttle. Driveability is another important factor, how drivers can apply the power to the tarmac. Some weeks ago Sainz said for the TV Honda PU is very good when they´re traction limited, but it´s lacking when they engage 5th gear and above. That means in Monaco Honda is probably a better PU than Renault, even if it´s providing less power (and that´s not sure).
Power is just one parameter in a PU, not the only one
Edit: and they do NOT use as much DF as possible because they can´t use the available power, they use as much DF as possible because the only drawback with DF is the added drag lowering top speed, but on a track like Monaco with no long straights, drag is not a big penalty because the average speed is very low, while DF is providing more speed trhough the corners wich basically means around most of the track, so it´s worth adding as much DF as possible
SmallSoldier
SmallSoldier
473
Andres125sx wrote:
diffuser wrote:
06 Jun 2019, 16:35
BrunoH wrote:
06 Jun 2019, 16:15
How would Sainz know if the Honda PU is very good if he has never driven a car with one in it?
