McLaren MCL34
f1rules
f1rules
634
Re: McLaren MCL34
Fabrega found first update
Lucky
Lucky
157
Re: McLaren MCL34
_cerber1
300
Re: McLaren MCL34
Re: McLaren MCL34
diffuser wrote:
12 Jul 2019, 06:21
PhillipM wrote:
12 Jul 2019, 03:54
I don't think the gurney was on the original wing, but I can't see much else different.
We still might see someting Friday or Saturday ...
I meant just on the wing as he was talking about, we knoe there's some new parts coming on the rest of the car this weekend.
Re: McLaren MCL34
They finally saw the light and removed that stupid plate on the barge board and replaced it with another chicken wing.
=D>
Re: McLaren MCL34
They haven't really got rid of it, they've just brought the multi-foil turning board forward and made it more extreme to do the same job - you can see the shape has changed right from front to rear. The leading edge of the floor seems to have changed slightly too so that may be the new floor already.
They're definately turning the flow out much earlier and more aggressively behind the front wheels now.
Re: McLaren MCL34
f1rules wrote:
12 Jul 2019, 11:50
https://pbs.twimg.com/media/D_RCSq_U8AApVq8.jpg
The gap between the barge board and that vertical device on the chicken wing is smaller.
f1rules
f1rules
634
Re: McLaren MCL34
When the last bargeboard update was added and flowvis pictures was there, someone in here mentioned there was still som gains to be had as there was some separation, seem that person was spot on as itd exactly that area that has changed 👍 now
Re: McLaren MCL34
PhillipM wrote:
12 Jul 2019, 14:18
diffuser wrote:
12 Jul 2019, 06:21
PhillipM wrote:
12 Jul 2019, 03:54
I've been speaking ill of that plate since they had it on the car back in 2017.
Re: McLaren MCL34
Maybe this is the heavier modular version of the floor where barge boards can be swapped rapidly. And a fixed, lighter version will be used for Germany?
Re: McLaren MCL34
Could be, you can see there's some epoxy fill where they've been altering things.
rccrdc
rccrdc
Re: McLaren MCL34
Are those deviators on the floor new?
101FlyingDutchman
101FlyingDutchman
Re: McLaren MCL34
I think so. Not seen them before!
Re: McLaren MCL34
rccrdc wrote:
12 Jul 2019, 15:38
https://ibb.co/5922VDB
That's the old midwing/Bargeboards but those 4 triangles folded back under "Estrella" is new... Good catch.
Re: McLaren MCL34
First Mercedes then Red Bull, now McLaren.
I know, just a coincidence, so I'm joking but they should hire me, as they seem to have focused on areas I've emphasized around here.
