Williams FW42
Big Tea
Re: Williams FW42
Post by Big Tea » Tue Aug 06, 2019 10:38 am
KiLLu12258 wrote:
Tue Aug 06, 2019 8:36 am
i think its not right way to search excuses for kubica. Russell is outperforming him since the beginning and this guy is getting better with every race.
I think on some tracks the disadvantage of kubica will cost him more on other tracks a bit less, but at all russell is just the better driver at the moment.
at all the kubica comeback was just a bad decision.
Possibly, but we have no idea how much of RK's feedback is contributing to Williams moving forward and the improvement in Russel. (not a RK apologist, just saying we do not know)
One test is worth a thousand expert opinions
netoperek
44
Re: Williams FW42
Post by netoperek » Mon Aug 12, 2019 4:40 pm
Roberts car last race. holes and duct tape...
roon
443
Re: Williams FW42
Post by roon » Mon Aug 12, 2019 9:00 pm
Robert: Did you fix the break?
Engineer: No, the brakes are fine. Checked them myself.
Robert: No, the break by the duct.
Engineer: Well all the brakes have ducts. Which one do mean?
Robert: The duct that has the break.
Engineer: I just told you, all the brakes have ducts.
Robert: No, the duct with a break. Can you just put a tape on it?
Engineer: Tape the brake ducts? I think rather not. Have you felt how bloody hot it is outside today?
Robert: No, I mean for the break. The break on the duct.
To be continued....
tomazy
155
Re: Williams FW42
Post by tomazy » Mon Aug 12, 2019 9:06 pm
We need more info than the last race. It is not from the race, becouse it is in the garage, is it from before the race? After the race? Is it from last race weekend? If so, in witch FP? Maybe it got damaget in the middle of the FP and they did not want to change it becouse they would loose to much time and then change it for the next practice? Do we have a picture from the actual race to see if this condition was there or not?
netoperek
44
Re: Williams FW42
Post by netoperek » Mon Aug 12, 2019 10:07 pm
https://pbs.twimg.com/media/DIELAmNWsAIUvOy.jpg
It's from sunday, 2h before the race, supposedly.
GarilNarbe
Re: Williams FW42
Post by GarilNarbe » Tue Aug 13, 2019 10:42 am
Shouldn`t be the green part also on the right side ?
ScrewCaptain27
511
Re: Williams FW42
Post by ScrewCaptain27 » Tue Aug 13, 2019 5:40 pm
https://uploads.disquscdn.com/images/ca ... e25db7.jpg
Probably broken or not yet installed.
- Serj Tankian
tomazy
155
Re: Williams FW42
Post by tomazy » Tue Aug 13, 2019 6:03 pm
The pic is not takan head on but at an angle, so the part highlighted in green is not visible becouse it is hidden by the chassis.
Squatch
Re: Williams FW42
Post by Squatch » Tue Aug 13, 2019 9:15 pm
They will have been fitted for pitstop practice and will have been swapped out again before the race.
netoperek
44
Re: Williams FW42
Post by netoperek » Wed Aug 14, 2019 10:45 am
Instances of such joyful creativity have been spotted on George's car as well, so You might be right there, I guess
ScrewCaptain27
511
Re: Williams FW42
Post by ScrewCaptain27 » Wed Aug 28, 2019 5:46 pm
AMuS
- Serj Tankian
Re: Williams FW42
Post by Morteza » Thu Aug 29, 2019 7:12 pm
Via AMuS
tomazy
155
Re: Williams FW42
Post by tomazy » Thu Aug 29, 2019 9:25 pm
A spoon rear wing
Via AMuS
humble sabot
Re: Williams FW42
Post by humble sabot » Fri Aug 30, 2019 6:50 am
Weird! Spoon wings usually show up more as high downforce variants. RB's is almost dead straight for Spa. But Merc is also running a more aggressive wing, so there might be some method to the madness. If I were to hazard a guess I might be able to come up with a reasoning for Williams, as they've struggled with balance and consistency and have nothing to lose in the standings, taking a hit on Vmax, might not bother them so much.
It's hard to tell for sure, but the floor appears to be revised.
the four immutable forces:
static balance
dynamic balance
static imbalance
dynamic imbalance
Racer X
Re: Williams FW42
Post by Racer X » Fri Aug 30, 2019 7:03 am
https://uploads.disquscdn.com/images/c8 ... 1446f0.jpg
When Senna had his accident didn't William weld together Sennas steering wheel the night before? Duct tape on some breaks'.
Should be fine...
“With your mind power, your determination, your instinct, and the experience as well, you can fly very high."___Ayrton Senna
