Scuderia Toro Rosso STR14
gastonmazzacane
Re: Scuderia Toro Rosso STR14
McMika98 wrote:
Thu Aug 29, 2019 5:03 pm
Finally a boomerang. Cant beleive it took half a season to get this piece of carbom fibre. Shows the deficiency in the team and factory.
It also took Ferrari a half a season to put a boomberang on.
So what does this piece actually do then? If it's such an easy thing, you should be able to give us chapter and verse about the air flow structures around this area and how this device beneficially affects them... :roll:
Marc.W
They had this at Germany did they not?
Marc.W wrote:
Thu Aug 29, 2019 6:44 pm
Yes, the new package was introduced in Germany.
McMika98
McMika98
-47
I thought they didnt race it. Regardless even Williams were early adopters to this concept. The team has a habit of falling behind in season which must be addressed with the new RedBull synergy.
Via AMuS
Marti_EF3
327
gokarter
gokarter
-21
what toro rosso needs to do is validate the aero upgrades. just for example. haas went backward with their new aero. they test both australia spec and their latest spec and found a slight negative. so really we never know if these aero upgrades work with comparing it with the original spec.
GhostF1
GhostF1
233
McMika98 wrote:
Thu Aug 29, 2019 7:01 pm
Do you get tired of talking rubbish and not adding anything useful to a technical Forum?
So far this year STR have brought more developments and are looking stronger than previous seasons
McMika98
McMika98
-47
GhostF1 wrote:
Fri Aug 30, 2019 12:57 pm
What races are you watching? Last few races the team have dropped back significantly. They were near top of midfield at the beginning.
gokarter
gokarter
-21
For onces I agree with mcmika98. TR has a habit of slowing down as the season progress. Last season the same . I know TR for bit lucky in Germany. But overall the team can't keep up the development rate
Webber2011
Webber2011
47
And Williams shot to the front of the midfield as soon as it was introduced 😂😂😂
GhostF1
GhostF1
233
McMika98 wrote:
Fri Aug 30, 2019 5:39 pm
What? What are you watching. They've been in the points for 6 our of the last 8 races. If you ignore unforseen issues which caused them to fall back, they are not going as badly as you're suggesting.
You're also taking the time to talk smack because of a boomerang element introduction date which is enough for me to usually skim over your nonsense.
Yes STR have a habit of dropping back second half of the season. Let's just see what happens. Too early to tell.
Capharol
60
GhostF1 wrote:
Sat Aug 31, 2019 12:54 am
TR gathered points but only for 9 or 10th place finishes, till Germany they were no where near the top of the midfield contender, and only because Kvyat took 3rd place at Germany they are so high up the ranks
Strive for continuous improvement, instead of perfection.
"Most people seem to turn off their brain when they turn on the computer and log in to social media."
restless
restless
25
Yes, but this year it seems McLaren is The undisputed 4th team on grid, so 9s&10s is ok
