Probably not since it's Kubica's sponsor.
They had talks, but it's all nice that Petrobras want's out but I'm sure there are contracts in place. It's not like the Brazilian state can do whatever they want.
https://sport.onet.pl/formula-1/orlen-w ... ha/cbezc46The third possibility Orlen was investigating was McLaren. When, a few days ago, we told people in the company that we knew about the visit of Orlen's representatives to London and the meeting with the heads of the British team, they were silent, then they tried to establish where we had this knowledge, and finally we were unofficially confirmed. The problem is that in McLaren there is virtually no room for Kubica, or at least that's how the band was supposed to present the matter during the first talks.
Should we be concerned by this trend of McLaren running above average DF since a couple of races before the summer break ?M840TR wrote: ↑11 Oct 2019, 11:38He could've easily been 2-3 tenths faster if not for the mistake in the final chicane where he excessively rode the first kerb. They've been quick enough today to match Redbull's race pace and end up within a second to pole but I'd say Carlos is being coy about it.f1rules wrote: ↑11 Oct 2019, 09:29sainz comment, which is very well documented in the numbers here
Sainz "Today's position corresponds to the performance. We need a little more speed in the straight, but having more load allows us to go better in the slow. In the first sector we are doing very well"
https://pbs.twimg.com/media/EGlAQM6UcAE ... =4096x4096
It's the better setup direction with thinner tread tyres. The car gets unpredictable really quick without it. Plus they suffer more than others on low-df since there's still no permanent & efficient solution to low-speed performance deficit.diffuser wrote: ↑11 Oct 2019, 13:46Should we be concerned by this trend of McLaren running above average DF since a couple of races before the summer break ?M840TR wrote: ↑11 Oct 2019, 11:38He could've easily been 2-3 tenths faster if not for the mistake in the final chicane where he excessively rode the first kerb. They've been quick enough today to match Redbull's race pace and end up within a second to pole but I'd say Carlos is being coy about it.f1rules wrote: ↑11 Oct 2019, 09:29sainz comment, which is very well documented in the numbers here
I don't agree with your analysis. How is Mclaren all of a sudden as fast as the RedBull through the corners in first and partially second sector? They're clearly running a lot more wing. And that's what's hurting them on the non DRS back straight, not the Renault.Juzh wrote: ↑11 Oct 2019, 17:07sainz's p7 lap from fp2 - 1.29.051
https://streamable.com/9538k
vs verstappen
https://streamable.com/yl7mq
As you can see mclaren holds it's own pretty well against verstappen here up until spoon corner, then gets completely demolished on the back straight. Bad ERS recovery after 130r is a tradition at this point for renault engines. Just look at how much speed sainz loses compared to verstappen at that stage. The sooner they're done with renault, the better for them. I don't think car itself is too draggy, since speed on the main straight is almost identical.
Sainz actually goes in to turns 13 and 14 ahead(1:04) but comes out behind Max(1:09). Max carries 10 KPH more speed thru the corner. Max also gets on the throttle a fraction earlier. Sainz never does recover more than half of that 10KPH before 15. It only appears to, since Max hits 15 earlier and has his speed drop off earlier.Juzh wrote: ↑11 Oct 2019, 17:07sainz's p7 lap from fp2 - 1.29.051
vs verstappen
Obviously when you get to top speed your advantage in acceleration will start to diminish. This doesn't mean renault out accelerated the honda here since sainz never reaches even close to verstappen's top speed.
Sure, whatever makes you feel better This speed drop of just after 130r has been renault's weakness for years and years, and nothing changed. I have similar clips like these ones from last year of both alonso and verstappen with renault power and they were nowhere after 130r speed wise. Just like this year.Benii6 wrote: ↑11 Oct 2019, 18:17I don't agree with your analysis. How is Mclaren all of a sudden as fast as the RedBull through the corners in first and partially second sector? They're clearly running a lot more wing. And that's what's hurting them on the non DRS back straight, not the Renault.Juzh wrote: ↑11 Oct 2019, 17:07sainz's p7 lap from fp2 - 1.29.051
vs verstappen
Well, I hope we'll have quali on sunday and we get to see how the Renault factory cars go after the 130r.Juzh wrote: ↑11 Oct 2019, 20:48Sure, whatever makes you feel better This speed drop of just after 130r has been renault's weakness for years and years, and nothing changed. I have similar clips like these ones from last year of both alonso and verstappen with renault power and they were nowhere after 130r speed wise. Just like this year.Benii6 wrote: ↑11 Oct 2019, 18:17I don't agree with your analysis. How is Mclaren all of a sudden as fast as the RedBull through the corners in first and partially second sector? They're clearly running a lot more wing. And that's what's hurting them on the non DRS back straight, not the Renault.Juzh wrote: ↑11 Oct 2019, 17:07sainz's p7 lap from fp2 - 1.29.051
vs verstappen
To me it's quite clear renault's energy recuperation on tracks with big dependancy on mgu-h is clearly lagging behind competitors.
Wow thanks for the videos and analysis . Yes both cars are perfectly matched up to spoon, and after 130R top speed before hitting brakes is 303km/h for RBR vs 288 for McLarenJuzh wrote: ↑11 Oct 2019, 17:07sainz's p7 lap from fp2 - 1.29.051
vs verstappen
