Williams FW42
Drica
Re: Williams FW42
Sevach wrote:
09 Sep 2019, 23:32
Given that Robert uses the same hand for up shifts and down shifts i wonder when he finds the time to press buttons.
Well, most of these are accessible with your thumb, and with gear changes being done with middle or index finger, its actually not that hard to press different buttons. And while on the subject, most of the changes regarding diffs and Bbal are done on the straights either between the shifts or after going through all the gears, not simultaneously
ScrewCaptain27
577
Re: Williams FW42
New front wing!
- Serj Tankian
pipex
Contact:
Re: Williams FW42
The main plane of the new wing looks very similar to the old one, as the location of the inboard wing tips (Y250 section). This new wing looks like it is a development along the same concept of the old one, but focused on reducing drag. I predict it will improve top speed a lot if it works :P
"We will have to wait and see".
Re: Williams FW42
I doubt it, the drag from the front wing config is tiny compared to the rest of the car.
pipex
Contact:
Re: Williams FW42
Good point. It would be interesting to know how/if the tire wake is affected by this change.
santos
Re: Williams FW42
Why are some teams following this trend? Isn't this the same concept as the Ferrari? And if you think how hard it was to make it work, why is Williams trying that?
Re: Williams FW42
Some more shots of the new front wing
tomazy
205
Re: Williams FW42
Cape under the nose is also new.
bill shoe
151
Re: Williams FW42
For reference, in Japan FP2 (may effectively be the qualy session) the Williams were 3-4% behind the fastest. And only 0.6 seconds behind the extremely not-quick Renaults. Just a sample of their speed near end-season.
LuisFeF1
125
Contact:
Re: Williams FW42
Williams FW42 Suzuka:
Wider and holeless pylons and new curved "cape"
Re: Williams FW42
Via Motorsport.com
Re: Williams FW42
Suppousedly a test for next year, will the team allow at least Kubica(reportedly Russell didn't like it) to run it this time.
Lotus102
Re: Williams FW42
Sevach wrote:
25 Oct 2019, 06:14
Latifi is in Kubica’s car for FP1. If they still only have one example of the wing, there’s little chance Kubica will get to use it in quali and the race.
Re: Williams FW42
Looks like Nicholas Latifi will run an aero test comparing new & old frontwing to start the first practice
Via @Tgruener
Lotus102
Re: Williams FW42
Supposedly Williams has three different front wing types at Interlagos this weekend. Anyone know any details?
Edit: I think somebody got the wrong idea on Twitter, and Williams actually has three of the new spec FW that debuted at Suzuka
