M840TR wrote: ↑Fri Oct 18, 2019 2:14 pm
diffuser wrote: ↑Fri Oct 18, 2019 1:56 pm
M840TR wrote: ↑Fri Oct 18, 2019 1:22 pm
Interesting. Could you elaborate on this?
Yeah, I don't get that. the Mexico track is 1.5kms shorter than japan. A full charge of the battery before a quali lap will be fairly easy to make it to the end.
Although, cause of the alititude, the turbo will be harder to spin up.
What confuses me is how the engine with consistently one of the worst ERS tech of the v6 era contributed to Redbull's win by virtue of its greatest shortcoming. Ferrari & Mercedes were & remain light-years ahead of Renault in this area, even with the lower turbine rpm. And let's not forget Renault was using its 2016 Mgu-k well into 2018.
I'm not even sure any of that is true, I haven't see a good comparison done by anyone that I would trust. Realy to compare the ERS between all cars you'd have to follow the cars around at each track and see how much of thier time they spend flashing red. I've never done that. Also deploying isn' a ON off thing, it can be varied. So you'd might deploy more if you running higher DF levels....I'm not even sure that would give you perfect picture.
With regards to Mexico, I think that whatever Renault are doing is allowing them to acheive higher spin with thier turbo. That in turn is letting them acheive higher boost and higher electrical genration.
