FW17
168
Re: 2021 Aero Thread
This is the first model the 2021 research team made; it looks to have a flat bottom with a 10mm plank
Not sure if this changed in the later iterations
jjn9128
769
FW17 wrote:
21 Oct 2019, 18:53
https://www.racecar-engineering.com/wp- ... 24x517.jpg
https://www.formula1.com/content/dam/fo ... /image.jpg
That's the "India" model. It's the 9th version of their car! There is a plank but it has a curved front edge.
#aerogandalf
FW17
168
jjn9128 wrote:
21 Oct 2019, 18:57
https://www.racefans.net/wp-content/upl ... -floor.jpg
Plank is going to be there to maintain minimum ride height. It was a question if the floor is flat or stepped
From your image it is still stepped, the height of the venturi tunnel throat is not zero (the height of the plank) but something more. It still looks reduced from the current step.
FW17
168
Mentioned in another thread that I liked the Champcar endplate in 2021 regulations
Just morphed an image
izzy
izzy
FW17 wrote:
21 Oct 2019, 19:34
outwash killer
MatsNorway
MatsNorway
Outwash killer indeed. I do not mind it either. Perhaps cleaner, so none of those strange outside vanes/wings on it.
Also.. that model looks really cool!
A touch of genius is the simplest thing.
DRS is like supports on a bicycle[/size]
Holm86
245
FW17 wrote:
21 Oct 2019, 19:34
https://i.imgur.com/kRUAlt2.jpg
Looks pretty good with these endplates, and with regulation it could be possible to keep them 100% parallel, without any outward curvature, preventing outwash.
But one thing I dont understand about the 2021 FW is why they want to keep it full width
jjn9128
769
They have to balance the rear downforce. From Pat Symonds on the F1 website
“I don’t think that eliminating front and rear wings is actually the right thing to do, there are lots of other aspects to it,” he said in an answer to a question posed on F1 Fan Voice. “We want cars that do work in turbulent air, even if we’re trying to reduce that very turbulence.”
Having wings is crucial to cars running in each other’s wake, and although the F1 cars when Symonds began working in F1 in the 1980s didn’t have such prominent front wings, he warned against a return to that era.
“Well… I wish it was that simple,” he said. “If you remember, probably in the early parts of my career, the cars were running with a lot of the downforce generated underneath the car, sometimes without the front wings and sometimes with the front wings that were used for trim, and actually not much of a rear wing.
“A lot of people think ‘Okay, they were great cars, they could follow each other’ but that’s not necessarily true. In fact we’re doing a lot of research into that at the moment with the view to producing a 2021 car that [would allow drivers to] race together and one of the secrets that we’ve found – and we’ve known for a little while, we’ve proven it now – is that you need a rear wing to pick up the wake, all the dirty air that’s behind the car, and lift it up over the following car, so it’s actually quite important to have a rear wing on there.”
And having a rear wing on an F1 car in turn necessitates a front wing...
“Once you have a rear wing there you have a lot of load all the way out on the back of the car so you have to balance it with something on the front."
#aerogandalf
Holm86
245
jjn9128 wrote:
22 Oct 2019, 13:55
I know, but it would still make more sense to have an "inboard" front wing, which then could be slightly taller to compensate, than a more flat full width front wing, its way too exposed and prone to break with contact
Lotus102
Holm86 wrote:
22 Oct 2019, 13:29
FW17 wrote:
21 Oct 2019, 19:34
Craig Scarborough told me that the full width wing plus flat endplate helped keep the airflow straight along the outside of the front wheel better than a shorter wing would
FW17
168
Did the new rules package get vetoed?
Autosport has something on their site which is behind a paywall
bauc
33
FW17 wrote:
23 Oct 2019, 16:43
It is related to the changes in Qualifications not Aero
jjn9128
769
Happy reg-day everyone. Latest teaser of the FOM model from F1
#aerogandalf
Still no DRS to be found. FW endplates look quite dramatic.
The endplates are actually slotted at the bottom. Interesting.
jjn9128
769
MtthsMlw wrote:
31 Oct 2019, 12:03
Just where the 3 elements of the wing curve into it. The lack of DRS actuator is promising [-o<
#aerogandalf
