McLaren MCL34
Bandit1216
21
Re: McLaren MCL34
PhillipM wrote:
25 Oct 2019, 15:43
RE: the rear wishbones producing lift - in isolation perhaps, but it's accelerating flow over the top of the diffuser and turning the flow inwards
Maybe that's why I'm not in F1 design.
But just suppose it weren't hypothetical.
M840TR
M840TR
315
Re: McLaren MCL34
Apparently the diffuser has received another update which will soon be tested with flo-viz, according to Ted.
f1rules
f1rules
634
Re: McLaren MCL34
According to mclaren.com norris was initially using the test floor with light measuremnt underneath that sainz stopped on track with in suzuka, and it said no new items, but they could offcourse be lying, but thats why norris had a floor change
SmallSoldier
SmallSoldier
488
Re: McLaren MCL34
f1rules wrote:According to mclaren.com norris was initially using the test floor with light measuremnt underneath that sainz stopped on track with in suzuka, and it said no new items, but they could offcourse be lying, but thats why norris had a floor change
So, they only use that floor for 2 laps? How much data could they have after a couple of installation laps?... The change was really quick though.
f1rules
f1rules
634
Re: McLaren MCL34
Well im not quit sure what they meassure with the light, i think maybe distance,
charliesmithhd
charliesmithhd
67
Re: McLaren MCL34
f1rules wrote:
25 Oct 2019, 20:58
Isn’t it usually ride height
Coefficient
Coefficient
Re: McLaren MCL34
It's to attract moths. The more wings the better.
f1rules
f1rules
634
Re: McLaren MCL34
Yeah my quess also
charliesmithhd wrote:
25 Oct 2019, 20:59
f1rules wrote:
25 Oct 2019, 20:58
trinidefender
trinidefender
318
Re: McLaren MCL34
SmallSoldier wrote:
25 Oct 2019, 19:45
If it's flowvis then that's sufficient. It could be a floor that pushes the limits a little closer to stall conditions to check correlation between CFD/wind tunnel and reality. Basically checking how accurate their simulation models are to the real world. For a very general example, If the team finds out that their simulation models are on the conservative side then they know that perhaps they can push future aerodynamic designs harder for more downforce.
I like that even though McLaren has developed their car well this year it seems that they are doing a lot of knowledge gathering for next year as well with quite a few visible experimental parts that clearly weren't intended to ever be raced being tested.
Re: McLaren MCL34
Look at the Power Limited... :shock: :shock:
michl420
michl420
Re: McLaren MCL34
If I unterstand that graph corect power limited means Corner with full throttle. This would suggest only ferrari running with more power. (or the others don't have the power)
M840TR
M840TR
315
Re: McLaren MCL34
The new engine cover wasn't used for the race.
Re: McLaren MCL34
Austin
Via AMuS
_cerber1
295
Re: McLaren MCL34
Nonserviam85
Nonserviam85
Re: McLaren MCL34
michl420 wrote:
26 Oct 2019, 12:24
Or they have more downforce which induces more drag that requires more power to maintain the speed...
