Steven
Owner
Contact:
Re: 2021 Aero Thread
Impressive work base_1000 !
Anyway, I was wondering what is the effect of removing rear wing endplates (more specifically, the part that currently sits on the high pressure side of the rear wing?
Is that just a way to reduce some downforce, and the strength of that vortex at the wingtip, while trying to keep a similar ad-surface on the rear wing? Is it aerodynamically less impacting for the wake than just a long AoA rear wing like in the current regs?
Beautiful images. =D>
As a 4 flap FW is allowed I wonder if anyone will even go for a 3 flap one as shown on the red model.
Great insight insidef1 and turbo and Jjn etc.
They should have gone even further and standardised 80% of the "floor" and diffuser, atleast for 2021 in order to set everyone on an equal footing, at least at the start of the new regs...
What about the car length/wheelbase and weight? will they try to reduce them?
base_1000
40
Steven wrote:
01 Nov 2019, 11:46
Thank you!
Here's the car untextured, the details and curves are more apparent. And here's the Behance project page if anyone is interested.
Holm86
243
Steven wrote:
01 Nov 2019, 11:46
I also have a hard time making sense of that rear wing, it seems really inefficient.
There will no doubt be a lot of spill over on the sides, and that will probably make two quite strong vorticies.
I think I saw in the demo video that they actually push the wake down, maybe thats a way to push down the following car??
Holm86 wrote:
01 Nov 2019, 12:49
Isn't the aim to generate a vortex that pulls in the wake and then lift it upwards and so clear of the following car?
As the diffuser is bigger etc., the rear wing doesn't need to be as efficient in order to get the overall downforce numbers.
Holm86
243
Just_a_fan wrote:
01 Nov 2019, 13:12
Holm86 wrote:
01 Nov 2019, 12:49
Take a look at 1:32 minutes, you can clearly see two large vortecies pushing the wake down
NOTE: You may have to open the video seperately in youtube, as F1 doesn't let you implement the video #-o
Edge of the floor slots still allowed.
Some flexibility in tunnel shape.
Sidepods and nose of course.
Cars will look good, let's see if they deliver on racing.
Hpefully DRS is less powerful.
jjn9128
769
Blackout wrote:
01 Nov 2019, 11:59
The floor is pretty standard.. there's a minimum and maximum shape for the tunnels (previous rules only even specified a maximum height for the diffuser) which doesn't leave a lot of room to play with. The diffuser endfence is also quite tight and there's not a lot of room to play with it. Then there's the minimum convex and concave radii. The vane surfaces are a little more open but still not huge freedom.
#aerogandalf
Holm86
243
Does the regulations say anything about serrated front wing planes?? Or does it have to be a constant line on the leading and trailing edge?
jjn9128
769
How do you mean? Like this? Image
EDIT: I think not
g. The rearward most point of every closed section, when projected in Z on to the reference plane, must produce a single tangent continuous curve with no radius of curvature smaller than 200mm.
#aerogandalf
Holm86
243
jjn9128 wrote:
01 Nov 2019, 14:04
How do you mean? Like this? http://cdn-8.motorsport.com/images/mgl/ ... detail.jpg
Exactly, if its legal, I can see some teams trying to generate vortices at the tips of serrations ...
Holm86
243
jjn9128 wrote:
01 Nov 2019, 14:04
EDIT: I think not
But how about the front edge??
