bigblue
Slo Poke wrote:
Wed Nov 13, 2019 2:18 am
Snorked wrote:
Thu Oct 24, 2019 1:27 pm
Photo three: the cart is in front of the horse!
Japanese reads R to L :-)
Slo Poke
Slo Poke
bigblue wrote:
Wed Nov 13, 2019 11:17 am
Aha! You’re only half right on that my friend. Top to bottom actually, with all resultant columns right to left.
bigblue
Slo Poke wrote:
Wed Nov 13, 2019 2:03 pm
OK, yes, you are correct, R to L for when text is vertical. This perception of R to L can change how you "read" pictures, e.g. Hokusai's "Great Wave" (ok, "Under the Wave off Kanagawa" to be more exact). Are the boats running from the wave or heading straight into it ?
Slo Poke
Slo Poke
bigblue wrote:
Wed Nov 13, 2019 7:02 pm
Judging by what is discernible of the boat/oarsmen, it appears the boats are heading into the wave. However all this does not alter the fact that Honda have blindly carried over from the early KERS years an excusable mistake made back then. (likely as not influenced by some of the teams adopting centrifuge KERS).
Think torque curves; vertical electric as opposed to ICE and mix it in your mind with the power to weight ratio. There’s two, three tenths begging there. The KERS motor, or call it what you want, really ought be at the rear of the engine, not crippled at the front.
nzjrs
124
Interesting. First on track engine failure for the season?
Bill
Bill
It's a Friday pu that have done its time
nzjrs
124
Edit: second failure? That was odd, cut out before any sign of smoke and then hit the barrier.
Friday engines certainly. Hopefully they get some information on the cause/s
HPD
397
https://twitter.com/AlbertFabrega/statu ... 1709191169
Tanabe: Towards the end of the session, the ICE on Gasly’s car failed and then Kvyat crashed due to a complete shutdown and with the team, we are now investigating the cause of both these problems. However, they have no effect on the rest of the weekend from a PU point of view, as both of them were running “Friday only” PUs, due to be changed tonight.
https://scuderiatororosso.redbull.com/e ... -practice/
https://en.hondaracingf1.com/races/2019 ... b=practice
The power is now on par with Mercedes in qualifying? Or is it because of altitude?
. 100!!. CEN . TUR.. ION. 100!!..
LM10
LM10
132
Sun Nov 17, 2019 12:59 am
Mercedes engineers told that they believe that Honda is strong in high altitudes which shows that they have advantages on electrical side.
Sieper
153
Altitude. It mitegates performance difference. But Honda is getting there. Hopefully they are now truely close.
Just a personal interest, a Family recreating a WW2 May 1940 Dutch warbird from scratch: https://www.facebook.com/FlyingFokkerD21/
siskue2005
194
LM10 wrote:
Sun Nov 17, 2019 1:17 am
No, high altitude performance comes from the ICE alone not the electrical side coz the high altitude has thinner air which favours engines with smaller Turbo (which Honda has).
Tzk
Tzk
25
I'm aware that the teams may use more than 4mj per lap as long as the "empty" and "fully charged" state of the battery are only 4mj apart, but maybe this makes Honda gain a bit of performance on short tracks? Or maybe this makes Ferrari suffer a bit more than everybody else, because their magical boost is from the ERS?
Bill
Bill
If Max didn't have a small lockup in austin he would have been pole so Honda has power everywhere not just high altitude tracks
