McLaren MCL35 Speculation Thread
pazazamadaz
pazazamadaz
Re: McLaren MCL35 Speculation Thread
NathanOlder wrote:
Fri Jan 17, 2020 8:49 am
Red Car with white details, like a Coca Cola Can :roll:
But you'd make the halo silver so it's like the ring pull on a can of coke. lol
Lucky
Lucky
156
NathanOlder
pazazamadaz wrote:
Fri Jan 17, 2020 10:14 am
=D>
GoLandoGo
Lewis v2.0
King George has arrived.
ThePapayaJaguar
ThePapayaJaguar
Emag
Emag
65
That is a very crude design. Although the shape might be close, I doubt the real thing will look exactly like it.
the EDGE
the EDGE
67
Nothing in F1 is done without reason, what could be possible reasons for this?
Is there a benefit to having a blade roll structure? So the double inlet design depicted by Scarbs would be Mclaren’s tidiest aero solution? Or could the double inlet be the real reason by offering a better aero solution, perhaps for drag or by increasing the effectiveness of the sharkfin?
I wonder if there could be a second raised inlet further behind too, as the side pod inlets have ‘size zero’d’???
NathanOlder
Do those 2 inlets look different in size? One looks higher than the other??
GoLandoGo
Lewis v2.0
bjpower
bjpower
-1
the EDGE wrote:
Fri Jan 17, 2020 12:51 pm
I remember when merc and lotus did the blade roll hoop they said the benefit was not aero but weight. I cannot remember was it lower cog or just less mass.
bosyber
bosyber
44
As far as I remember the Merc. 2010 blade had to be heavier than the hoop (round shape distributes forces better, and the minimum width of the blade has been increased after that season), and it was more about creating freedom to change the shapes around it.
But, here I don't see any blade in between, so maybe McLaren are doing something else.
f1rules
f1rules
538
and here it is, wrapped unfortunately :-) from their app
_cerber1
231
Ivan is intriguing in the comments. He says the chassis is good on paper. In general, he is positive. [-o< [-o< [-o<
https://twitter.com/ivanlda/status/1217804612511641601
rgava
rgava
NathanOlder wrote:
Fri Jan 17, 2020 1:14 pm
That's the effect of the distortion due to the curved reflective surface of the helmet.
You can see the same distortion in Sainz head (which is not as asymetrical as it seems in the image :lol: )
NathanOlder
rgava wrote:
Fri Jan 17, 2020 2:34 pm
They look a different size in all the pics, not just Carlos reflection
GoLandoGo
Lewis v2.0
JRindt
I believe that one opening on the airbox is behind the other, rather than both being beside each other. Something like the ones used by Ferrari and Mercedes a couple of years ago, but only larger.
thestig84
thestig84
JRindt wrote:
Fri Jan 17, 2020 7:02 pm
Nice idea but no way the second hump could be as large as in seat fix still and behind. I like scarbs drawing but agree one does look larger and perspective would normally mean the larger one should be smaller, interesting
