2021 Engine thread
mzso
59
Re: 2021 Engine thread
Holm86 wrote:
09 Feb 2020, 13:55
And a higher percentage of biofuel, which will mean less power
I fail to see how that's true.
Holm86
243
mzso wrote:
13 Feb 2020, 18:16
Holm86 wrote:
09 Feb 2020, 13:55
Because ethanol has much less energy density compared to the normal race fuel
617
and more to the point butanol has 34.4 MJ/kg
less than 80% of gasoline's
mzso
59
Holm86 wrote:
13 Feb 2020, 18:37
mzso wrote:
13 Feb 2020, 18:16
Holm86 wrote:
09 Feb 2020, 13:55
Ethanol is not "the biofuel". Only one kind. I don't remember any particular restrictions on biofuel, from when I looked at it. Is there any?
Holm86
243
mzso wrote:
13 Feb 2020, 20:17
Holm86 wrote:
13 Feb 2020, 18:37
mzso wrote:
13 Feb 2020, 18:16
Not the only one no, but I don't know any biofuels that as high energy content as regular gasoline
Dr. Acula
46
mzso wrote:
13 Feb 2020, 20:17
Holm86 wrote:
13 Feb 2020, 18:37
mzso wrote:
13 Feb 2020, 18:16
In the F1 rules? Nope. So far the FIA didn't define what exactly they mean with "Biofuel".
Propably they go for BtL (Biomass to Liquid) which basically allows you to produce any kind of liquid fuel you want, even petrol.
617
commercial intent is (or was) the restriction
this requirement seemed to permit bio-butanol (as we have been shown with Honda)
but not yet anything made from it ???
Holm86
243
Tommy Cookers wrote:
13 Feb 2020, 21:55
Butanol is only slightly less energy dense than gasoline, but definitely much more dense that ethanol
But isn't it expensive and difficult to produce?
mzso
59
Holm86 wrote:
13 Feb 2020, 22:12
That never mattered to F1.
mzso
59
13 Feb 2020, 21:55
Oh yeah...
They might as well go for propane or butane. They are both widely used commercially.
617
propane/butane etc content is strongly limited by restriction on fuel composition by carbon atom count and vapour pressure
ok within those limits using bio propane/butane could make sense - minimising loss from biofuel overall
and isobutanol ie bioisobutanol matches gasoline in mass-specific energy
btw butanol could have been useful in 'old' F1
having much higher heat per mass of air than gasoline or the lower alcohols eg ethanol or methanol
ncx
ncx
19
In the 2021 fuel regulations, they go to some extent in describing "Advanced Sustainable component" and "Second generation biocomponents" in the Fuel definitions section, but then in the Composition of the fuel section the only mention of biofuel is this:
16.4.4 A minimum of 10% (m/m) of the fuel must comprise advanced sustainable Ethanol.
It seems the details are still work in progress, which would also explain the absence of the race fuel max allowance, while the max fuel flow rate is kept at 100kg/h.
NL_Fer
82
What economy on a downhill, how much chance on a ICE/TC/H freeze for 2021? Honda and Renault will take major hits in car sales/profits.
Bill
Why single out only those two the whole economy not just car industry will be affected including survival of small teams like Williams.
