Mercedes W11
Seanspeed
Seanspeed
Re: Mercedes W11
KeiKo403 wrote:
20 Feb 2020, 14:43
at the moment it looks like Merc are using this on the straights only, this affects the toe and straight line speed of the car. In simple terms that's the general thinking right now anyway.
This morning we've seen a kind of binary setting. In/Out or On/Off...so my question is could we see this developed further or has further development already been done and we're just yet to see it? Could we see the steering wheel be moved to lesser degrees based on high/medium/low speed corners or just purely based on corner types, the snail like T2 at China or various corners around Monaco etc?
Is the only benefit with this system on straights?
Should have a tremendous advantage for tire wear.
Jip
Jip
Re: Mercedes W11
djones
djones
Re: Mercedes W11
rohan wrote:
20 Feb 2020, 14:49
The rules are clear - suspension changes can only be made when the car is stationary, so the system is 100% illegal.
I wonder if Mercedes will get as much stick as Williams did last year for having something so clearly against the rules on their car.
1. Its not a suspension change. If it is then turning the steering wheel is also a suspension change.
2. I'm confident the 6 times back-to-back champions Mercedes know if something is or is not "100% illegal".
GPR-A
37
Re: Mercedes W11
rohan wrote:
20 Feb 2020, 14:49
Toe adjustment IS NOT SUSPENSION change! Most teams get clarifications from FIA when they are implementing their ideas for their legality. Once they have sufficient discussion around it and find it to be perfectly within the framework of legality, it's then implemented. Mercedes have more to lose if they irresponsibility went ahead and implemented something that is, let alone being legal, even doubtful. FIA has already said, it's legal. But they want to see if it is also safe.
rohan
rohan
-1
Re: Mercedes W11
w1Y wrote:
20 Feb 2020, 14:52
rohan wrote:
20 Feb 2020, 14:49
you haven't been reading have you otherwise you would have read the counter argument to your accusation
I've read the counter-arguments and they just don't hold any water.
Re: Mercedes W11
Bravo Mercedes...
Legal or illegal =D> =D> =D>
NathanOlder
Re: Mercedes W11
rohan wrote:
20 Feb 2020, 14:49
But its not adjusting the suspension
GoLandoGo
Lewis v2.0
King George has arrived.
i70q7m7ghw
i70q7m7ghw
49
Re: Mercedes W11
Jip wrote:
20 Feb 2020, 14:53
Exactly what I said earlier, they would have already invited an FIA delegate to assess it when they were developing it. McLaren did exactly the same when they came up with the f-duct.
This isn't going to be instantly banned, it'll have to go through the protest process which will take months, so people have stop beating the "100% illegal" drum now.
Re: Mercedes W11
rohan wrote:
20 Feb 2020, 14:49
If it's illegal then steering is illegal as steering changes the suspension settings.
F1Krof
96
Re: Mercedes W11
turbof1 wrote:
20 Feb 2020, 13:45
F1Krof wrote:
20 Feb 2020, 12:33
I do not believe that is what is going on. It could be for driver's preference, since they're sharing the car with Bottas.
But that is something they would change in the garage, not spend what must be a huge lot of resources on suspension mechanisms and packaging, just so the driver can adjust it on the fly. This is definitely something they want to run for the races.
We do not know it connects to the suspension for sure. Only Merc (and FIA) knows it for sure. We're all speculating at this point. Who knows maybe it is what everybody is suspecting, maybe it is for driver comfort adjustment, maybe it is because of the driver swap, or even maybe it is red herring to throw everybody out while the "real" devil is somewhere else completely.
I just don't know why would a team invest so much in money, and potentially hindering the development in that particular area when something like this could easily be protested and banned.
Wroom wroom
Re: Mercedes W11
Scarbs:
Re: Mercedes W11
Marc Priestley:
Re: Mercedes W11
F1Krof wrote:
20 Feb 2020, 14:59
turbof1 wrote:
20 Feb 2020, 13:45
F1Krof wrote:
20 Feb 2020, 12:33
-We can definitely see the toe angle changing.
-We can definitely see the steering wheel being pulled backwards and pushed forwards.
That's not speculation, that is what is visible present. A team would never introduce a whole heap of complexity into a "on the go toe adjustment" feature for driver comfort/preference. If that was the sole purpose, they just burned a few millions and a lot of time at least on something they can do in the garage as well. It is a very safe assumption they do this for performance.
I can't say if this idea will stick legally. Mercedes will definitely try.
Sawtooth-spike
Re: Mercedes W11
rohan wrote:
20 Feb 2020, 14:54
w1Y wrote:
20 Feb 2020, 14:52
rohan wrote:
20 Feb 2020, 14:49
What more likely, Merc running a system that they know is 100% illegal for fun or They have found a loop hole to exploit that is in a nice grey area of the rules?
Its only Illegal until the FIA say so.
I believe in the chain of command, Its the chain I use to beat you till you do what i want!!!
jetho
jetho
Re: Mercedes W11
GPR-A wrote:
20 Feb 2020, 14:53
rohan wrote:
20 Feb 2020, 14:49
Not saying there is anything wrong with what you said, but FRIC was also legal...until it wasn't.
I'm sure Merc has cleared the idea before with the FIA. I'm also sure that the other teams will raise some points with the FIA and apply some pressure.
I'm definietly not sure that the initial 'OK' Mercedes got from the FIA will hold ture until Melbourne. This is a legal/political battle from now on. Who knows who will win...a new technical derective can change things pretty quickly.
