COVID-19 could affect more races this year.
Phil
66
Re: COVID-19 could affect more races this year.
Fulcrum wrote:
27 Mar 2020, 18:14
The CFR in Germany isn't increasing much, if at all, if you consider the lag effect between confirmed diagnosis and outcome (death or recovery).
If you model deaths recorded "today" as a function of prior cases, where "prior" can mean anything between 5-15 days, then Germany's CFR has remained fairly constant relative to a lag of 7 days; this rate being ~ 1.7% of confirmed cases.
I mentioned the CFR increasing in Germany relative to actual registered positive cases (currently at 0.6%). You are right though, the increase seems to be less in Germany, than in other countries - but it is increasing.
The speed at which it increases IMO is directly linked to the capacity of the health system. A health system operating well within its limit can keep patients alive. One that is operating over, can not and people die [sooner] without help. Germany is still at a very low number relative to its population. If you check Switzerland however, you'll see that our number of cases per population is in fact higher than Italy itself.
Some of these numbers are a bit skewed though, obviously. If you have the ability to count more, you are likely to have more positive cases (most countries are limited in their ability to test, not people infected). And I assume the fact that our country is only testing people with severe symptoms will also have an impact on the current CFR. However, as time goes on - people who don't have symptoms, might develop symptoms until eventually showing up at a hospital with severe symptoms and get counted then. Others who survive the illness without leaving their home might never show up in our statistics, because they'll never get counted/tested.
It is my personal opinion that we are far too early to be making any predictions or assessments if we'll go the way of Italy (and Spain) or if our countries defeat the numbers.
In Switzerland, we're 1 month (30 days) since the first case tested positive. Considering many cases develop symptoms only after 5-10 days, start out with very mild symptoms for a week until possibly developing more severe symptoms, I don't know - numbers of fatalities could explode here too to the point we'll be seeing a similar surreal CFR.
I assume Italy wasn't much different - I think people have been infected and showing signs of the illness way before they actually started testing, thus their CFR started out way higher than anyone elses. In other words; they were well into the progression of the pandemic when they started testing and people showing up at hospitals.
Compare that to Germany, where they obviously started way earlier with a well established process of testing.
#Team44 supporter
Phil wrote:
27 Mar 2020, 20:16
It's also worth noting that more of Germany's cases are younger (in so far as they are in their 50s rather than in their 70-80s) than in Spain and Italy. Age is not helpful with this illness. The old are much more likely to die from it so if you have proportionally more older patients, you'll get a much bigger fatality rate.
Germany also has a good level of critical care beds / population compared to many others (nearly 3 times the level in the UK, for example).
nzjrs
60
Here's a decent overview of covid / influenza-like virus mutation (read the whole thread)
strad
117
HMMmmmmm
Yesterday the CDC said that the virus showed no signs of mutating. :?
Sir Stirling Moss
The US CDC seem to be a rare beast in thinking that. Lots of stuff on line about changes to the virus and how they are being tracked through genome sequencing.
e30ernest
e30ernest
27
Just_a_fan wrote:
28 Mar 2020, 03:23
I think the US organizations are under political pressure to make the virus fit a narrative. It murkies the waters a lot making it more difficult to get reliable information.
DChemTech
DChemTech
45
strad wrote:
28 Mar 2020, 02:56
HMMmmmmm
Any virus mutates constantly. I do presume they know that at CDC. Perhaps they were afraid that the general population would translate 'mutates' to 'gets worse', and there are indeed no clear signs of that. Drawback of that strategy is that you do confuse people that do know what mutation is.
It is mutating slowly is what they mean to say. A family member of mine works in genetics.
Big Tea
Sevach wrote:
28 Mar 2020, 19:44
https://www.motorsport.com/f1/news/ferr ... n/4774280/
Latest idea for F1 i guess.
Bet there would be a real scramble to have the Christmas GP
izzy
izzy
Big Tea wrote:
28 Mar 2020, 20:10
Sevach wrote:
28 Mar 2020, 19:44
lol there would wouldn't there! I wonder if they'll start thinking about 2 races in one place, once they find they're starting in October or whatever
strad
117
28 Mar 2020, 13:49
Yes that was their point. That it wouldn't show any real mutation for maybe a year. Not like it's changing faster than we can keep up with.
They also said their models were based on wrong numbers and thus their results derived from them were wrong.
Computer models are always in danger of GIGO.
Sir Stirling Moss
FrukostScones
ENGINE TUNER
ENGINE TUNER
25
Good news everybody!!!
waynes
waynes
so what tech are Mercedes HPP using?
their own injection system?
genuine question and very interested how they'll be able to produce a 1000 a day (off the BBC's story)
https://www.bbc.co.uk/news/health-52087002
