It is not a technical one, so no need to worry about car design. Because of that there is a good chance that the car submission will still be on Sunday night.
For more info, I have to wait for Richard though.
But who has the veto?
jjn9128 wrote: ↑04 May 2020, 12:53What's the top surface doing? Have you got more low pressure above or less high pressure? Outwash around the front of the floor can affect the high pressure region ahead of the rear wheels or the peak diffuser flow. Is your total force better even if the floor is worse?Joe7218 wrote: ↑04 May 2020, 12:43I'm really at a loss with what's happening with my floor performance. I've lost 3/4 of my downforce (currently making -0.3) and the only thing I've changed is the sidepods slightly. The floor plank is still producing the same amount and the pressure patches look better then they did when the floor had a cl of -1.2?
Difficult to help without pics but understandable if you're not keen to share.
I do
The second image that high pressure region ahead of the rear tyre is definitely bigger than the first, not sure if it's 0.3Cz bigger but that will be some of it. I'd say the 3rd image looks like there's a hole in the mesh or something, you'd normally get some outlandish result like a 400Cz with a hole but I'd start by checking the mesh is water tight.
Yeah, sounds a bit bad at first sight. I will present all teams though and those that do not go through qualifying simply use the submitted time as race time. And then we do not know into how many submissions these 50 registered teams will materialize.jjn9128 wrote: ↑05 May 2020, 09:17The second image that high pressure region ahead of the rear tyre is definitely bigger than the first, not sure if it's 0.3Cz bigger but that will be some of it. I'd say the 3rd image looks like there's a hole in the mesh or something, you'd normally get some outlandish result like a 400Cz with a hole but I'd start by checking the mesh is water tight.
Wow 50 to 15 is a serious pre-qualifying cull![]()
This is your own strategic decision. Keep in mind, you are supposed to submit a time that you will beat. So even if you are 100% sure about your simulation, you should probably shave a few tenths off of your submitted time.
thanks for your advicejjn9128 wrote: ↑05 May 2020, 09:17The second image that high pressure region ahead of the rear tyre is definitely bigger than the first, not sure if it's 0.3Cz bigger but that will be some of it. I'd say the 3rd image looks like there's a hole in the mesh or something, you'd normally get some outlandish result like a 400Cz with a hole but I'd start by checking the mesh is water tight.
Joe7218 wrote: ↑05 May 2020, 10:43thanks for your advicejjn9128 wrote: ↑05 May 2020, 09:17The second image that high pressure region ahead of the rear tyre is definitely bigger than the first, not sure if it's 0.3Cz bigger but that will be some of it. I'd say the 3rd image looks like there's a hole in the mesh or something, you'd normally get some outlandish result like a 400Cz with a hole but I'd start by checking the mesh is water tight.
wouldnt the larger high pressure region in the second image mean it should have more downforce then the second image though (all else being the same)?
