[MVRC] Mantium Virtual Racecar Challenge 2020 (Grand Prix Cars)
yinlad
Re: [MVRC] Mantium Virtual Racecar Challenge 2020 (Grand Prix Cars)
jjn9128 wrote:
25 May 2020, 12:53
yinlad wrote:
25 May 2020, 12:44
on a side note I've run a test case with just a rear wing to find it's absolute performance in clean air... safe to say I think I have some air flow issues on the whole car :oops:
What direction is the flow moving? You might have to nose it up a bit to align it to air box wake. Alternatively a downwash wing just behind the cockpit should help push that dirty air under the rear wing.
after the changes I made for this test it's mostly cooling exit and front tyre wake coming inboard and stalling the wing. Also having never postprocessed in paraview until now, I feel my eyes have been opened significantly....
MVRC - Panthera
jjn9128
780
Yeah front tyres suck. If only they could be covered... 🙄
#aerogandalf
Joe7218
Joe7218
yinlad wrote:
25 May 2020, 12:44
Theoretically, how would one post process in paraview? purely theoretical question :lol:
yinlad
Joe7218 wrote:
26 May 2020, 03:53
yinlad wrote:
25 May 2020, 12:44
After you run a sim you can find various .vtk files in the 'postProcessing/sampleDict' and 'postProcessing/Sets' folders, you can open these in paraview, which is obviously a lot more useful than just relying on generated pics like I was doing haha. It's worth loading the SurfaceLIC plugin when looking for U_nearwalls. Googling SurfaceLIC should get you some results on how to load that in and select it for a data set
MVRC - Panthera
LVDH
52
Joe7218 wrote:
26 May 2020, 03:53
yinlad wrote:
25 May 2020, 12:44
I highly recommend to go through appropriate tutorials first. Either from the Paraview homepage directly, although these are very general, or by going through the Paraview section in the OpernFOAM documentation. If you just jump right into it with our "advanced" simulations, you will just be going through a bunch of avoidable rookie mistakes.
Thomas2019
Thomas2019
For those with too much time on their hands, there is an ongoing effort with getting the VTK pipeline directly into Blender.
https://bvtknodes.readthedocs.io/en/lat ... Nodes.html
https://blenderartists.org/t/bvtknodes- ... /1161079/3
I played around with it last year, but found it not superior to my usual postprocessing workflow, yet(!). It has made some progress since then, though. And more people try to use it and provide feedback.
Thomas
AratzH
You might find this useful. I have a Paraview scene template I use to post process all cases. If you go to File/Load State and choose this file it will give you the option to choose the case location. Once you select everything and wait for a while you will have the whole case loaded with cut planes, surface, VTKs, some streamlines, etc.
MVRC -> TF
yinlad
Image seeing some weird behaviour on my inlet surface, anyone seen this happen before? #-o =P~
MVRC - Panthera
LVDH
52
Thomas2019 wrote:
26 May 2020, 09:48
Thomas
That sounds pretty cool. I am working on something similar. I will have a look at this. Maybe one day, we can have a cool approach for very cool OpenFOAM post-processing.
yinlad wrote:
27 May 2020, 09:51
make sure the engine inlet surface does not just touch the inlet duct but actaully intersects it, so you are sure it is sealed properly.
I just had the honor of checking half of your cars. I found very few violations (Chris found more , better eyes???). I have to say I like the cars very much. After seeing them more in detail, I have to say JJR will be high on top and I like the MT Race Enginneering and the MaccaRacing cars very much.
CFD is pretty much done, so I guess we will post the scrutineering results soon and the results should be out this Sunday, which is great.
MaccaRacing
MaccaRacing
LVDH wrote:
27 May 2020, 19:53
:oops: what do you like about my car?... well, I am honoured to read this :D
LVDH
52
Not sure if I just like the overall lines on the car, the diffuser strakes or if it is just the color scheme. I think the best colors are on WBRacing though and that will probably also be a pretty strong car. In the end it does not matter, the numbers will tell which car is best.
yinlad
LVDH wrote:
27 May 2020, 19:53
thanks will check that out. It's an exact face at the moment so will try scaling it up a bit to intersect. I've actually managed to balance the car a little better with my new parts now so round 2 should see 90% of my car change from Monaco... :oops:
MVRC - Panthera
LVDH
52
yinlad wrote:
27 May 2020, 22:38
LVDH wrote:
27 May 2020, 19:53
Well it is only "exact" when all nodes of the surface are "exactly" on a node of the inlet duct. That is something I would not count on. And I do CAD cleanup on all of your cars and on most them, I do not take any chances and scale the surface up a little bit.
wb92
LVDH wrote:
27 May 2020, 21:09
Haha, looks like with the colors the only positive thing so far for the new season! I was wondering if placing color details in such way would work, apparently it did, so thanks for that :)
#redisfaster
by the way - could it really be that super strong outwash concepts are washed out (pun not intended) due to the narrow mesh refinement outside of the car?
MVRC - WBRacing
AratzH
I actually did a mesh sensitivity study regarding precisely the effect of the coarse region in out wash. I probably don't have the most aggressive execution, but it definitively affects things.
This two pictures are simulations of the same geometry at Z=-0.1. The first one is the MVRC template. The second one is the settings we use at work, slightly different mesher, but same solver settings.
As you can see the out wash is a bit different, the one from the front wing seems stronger in MVRC. The main difference is the tire wake and the out wash generated by the barge boards.
Nothing to be worried about really, since we all play by the same rules, but interesting as a theoretical debate.
MVRC -> TF
