Just to add on Hamilton's penalty.
Rosberg also received penalty in Germany for pushing Verstappen wide.
And Rosberg was on full lock, in a hairpin, with his approach compromised by Verstappen agresive movement under breaking.
You cant use full lock unless your going slow enough. Turn 4 isn't a full lock corner. Lewis was using the maximum amount of lock he could use. Its all about the amount of usable grip that determines what your maximum lock is.
He's actually my driving coach
Yeah I think the people who are citing him not going full lock has never driven a car at the limit before.NathanOlder wrote: ↑08 Jul 2020, 10:10You cant use full lock unless your going slow enough. Turn 4 isn't a full lock corner. Lewis was using the maximum amount of lock he could use. Its all about the amount of usable grip that determines what your maximum lock is.
When push came to shove, Merc was able to lap as fast as NOR/LEC who were on 25-lap fresher and softer tyres, so I don't buy the argument that they didn't pit because of mechanical concerns.basti313 wrote: ↑07 Jul 2020, 16:56Only with going flat out, which Merc did not want to do from lap 2...mkay wrote: ↑07 Jul 2020, 15:15ALB/NOR/LEC were catching up to BOT/HAM due to the latter being stuck being the SC for 3/4 of a lap.PlatinumZealot wrote: ↑07 Jul 2020, 14:50Albon had pitted twice already? Sure? How was he so close then if he had pitted twice?
All I am saying is that even if they missed the chance to pit on L51 (like ALB/NOR/LEC), they could have done so a lap later - they would have lost minimal track position. I think they should have fancied their chances against ALB on fresh rubber.
Plus a car which showed up to be problematic in traffic over the last seasons...
No idea where you can come to the conclusion that it would have been a discussable solution for Merc to pit the cars behind three other cars.
Agreed, 'maximum lock' would be a much better choice (not only more accurate but it also inherently references the relevance of speed).NathanOlder wrote: ↑08 Jul 2020, 10:10You cant use full lock unless your going slow enough. Turn 4 isn't a full lock corner. Lewis was using the maximum amount of lock he could use. Its all about the amount of usable grip that determines what your maximum lock is.
There are some contractual issues as well. There are obligations on both sides for the original GP names.With new names they are able to circumvent those obligations.
I have to disagree.langedweil wrote: ↑08 Jul 2020, 06:10Lewis is only Lewis when he's way ahead into the distance, preferably 30 wdc points ahead, in car that is .5 of a second faster than any other car on the track.
The more things tighten up, the more the frustration levels rise, the more prone to error he becomes. Impossible to check, but would he have taken P2 in Lec's car ? I doubt it ...
Oh, yes, that part of the analysis I agree with. I just don't think that this: "Now the stewards made this a non risky move next time" is necessarily correct because Albon took a risk and got the shorter end. Hamilton's penalty was a yoke compared to Albon's, so... you'd still think twice about pulling that move, wouldn't you?Jolle wrote: ↑07 Jul 2020, 23:58Bit like a dive bomb but then from the outside. The late overtake around the outside compromised Hamilton’s ability to react on Albon being in his path out the corner.6 of 12 wrote: ↑07 Jul 2020, 23:51Although I don't fully agree with your analysis, I have to say that I am usually the first person to demand that Hamilton be penalised, however, in this case, I thought it was a racing incident. (Obviously my heart was still very happy with the decision, but my brain knows... yeah.)Jolle wrote: ↑07 Jul 2020, 23:48Albon made a risky move going round the outside, late. The risk was that his “gap” could disappear before he completed the move, because the inside car is committed to a certain minimal radius when you pick your apex point. Part of a risky move that it can backfire, as it did. Now the stewards made this a non risky move next time, you just have to be just ahead around the apex, which isn’t that hard to do with the extra speed going the long way round.
Good vid. I found it pretty convincing and its explanation of the physics involved was clear and well delivered.
Nopes. You dont win 6 WDC out of sheer luck. 2018 season was close with Lewis trailing Vettel in first half of the season, yet he won.langedweil wrote: ↑08 Jul 2020, 06:10Lewis is only Lewis when he's way ahead into the distance, preferably 30 wdc points ahead, in car that is .5 of a second faster than any other car on the track.
The MP4-24 until the major update was the only dog he drove, that car is also the only one his teammate didn't win a race in despite it being one of the fastest cars on track to close out the 09 season. He has had the best run of cars of any driver ever.Unc1eM0nty wrote: ↑08 Jul 2020, 11:13I have to disagree.langedweil wrote: ↑08 Jul 2020, 06:10Lewis is only Lewis when he's way ahead into the distance, preferably 30 wdc points ahead, in car that is .5 of a second faster than any other car on the track.
Lewis has driven some cars that were dogs as well, he's won races in every season he's competed in. It's usually when the
car is poor that he has the biggest gap to his teammates.
He just needed to change his approach to turn 3 then hd would have been on Bottas gearbox at T4, but he was consistently 3/10ths slower through turn 3 using his wide square line, hopefully he makes that adjustment for this weekend.damager21 wrote: ↑08 Jul 2020, 13:23Nopes. You dont win 6 WDC out of sheer luck. 2018 season was close with Lewis trailing Vettel in first half of the season, yet he won.langedweil wrote: ↑08 Jul 2020, 06:10Lewis is only Lewis when he's way ahead into the distance, preferably 30 wdc points ahead, in car that is .5 of a second faster than any other car on the track.
Consistency is the key - he holds the record for most consecutive points finishes in F1 history, bringing his total up to 34 races. And this has nothing to do with car with 0.5secs advantage
In the last race, he managed to close the 6sec gap between himself and Bottas in matter of few laps. Without gearbix sensor issues / team order, Lewis would have definitely overtaken Bottas.
Just like in the real world, people can say just about anything, as long as they aren't openly/directly hostile, caveats exist of course.
