High Performance Road Cars VS Bikes.
Bonker T
Re: High Performance Road Cars VS Bikes.
Here is another car vs bike on the Ring.
Tim.Wright
330
It's a pretty simple equation. Bikes are faster in power limited conditions (throttle = 100%) and the cars are faster in grip limited conditions (throttle < 100%)
Phil wrote:
08 Jul 2020, 11:59
J.A.W. wrote:
07 Jul 2020, 23:56
No imagination required, the topic is about road machines, not G.P./Formula racing,
however, roadbikes were pulling ~1G in stopping tests ~1/2 a century ago, & since
the advent of disc brakes back then, certainly keep that braking level - sans fade
no matter how often it is applied - while any but super-expensive cars will have
their warning lights flashing - as their soft street pads are baking from heat-soak.
Flashing lights? This is just hilarious and has zero to do with braking ability. And if you are referring to flashing braking lights... ever heard of ABS? It’s due to traction limit while under braking.
Under most road legal speeds, braking ability is limited by traction, not brake caliper size or heat dissipation.
Do the math; force/weight by contact patch and tire grip levels. Also factor in CoG and weight transfer. In the end, you still have way more contact patch and mechanical grip in a car than a bike.
And the fact that no matter how hard you brake in a car, it doesn't rotate around the front axle and stick you face first in to the tarmac with the car on your back. Unlike bikes which can, and do, do exactly that.
Andres125sx
Bonker T wrote:
09 Jul 2020, 12:06
https://www.youtube.com/watch?v=-2976rRzb3s
a good one! =D>
Andres125sx
Tim.Wright wrote:
09 Jul 2020, 12:53
It is this simple, with the exception of straighter lines bikes can do on some corners wich are not too common on tracks but are on roads
But that´s when we´re talking about street cars and bikes with very different power/weight ratios, if you compare with a supercar or racing car with a more similar ratio (not even the same) cars solve its disadvantage and beats any bike fair and square, while a bike, even a MotoGP, can´t improve grip limited conditions that much so its disadvantage remains even when comparing best racing bikes with normal racing cars
J.A.W.
109
Phil wrote:
08 Jul 2020, 11:59
J.A.W. wrote:
07 Jul 2020, 23:56
Have you never driven a current road car hard enough to have the dash-console warning lights:
brake/ABS/stability control - light up urgently, cause a 'limp mode' response - meaning an expensive
dealer-check system recode? Its not so "hilarious". Those are the "flashing lights" I was referring to.
As for the maths, unless the car has real aero downforce, & is travelling fast enough to use it,
then the power-to-weight advantage of the bike trumps the car, esp' given the tyre adhesion
factor of modern sportsbike rubber, so by all means check the video/track records of speed/time,
comparing road going vehicles (even without taking traffic issues into account).
Sure, certain cars would have an advantage on rough, irregular or broken road surfaces,
like a rally special stage, yet the real-life traffic factor may still intrude here, too.
J.A.W. wrote:
11 Jul 2020, 00:19
Phil wrote:
08 Jul 2020, 11:59
I've driven fast cars fast enough for long enough that the brakes cry "enough" and I've also had the tyres do likewise. I've never, ever, not once, driven a car so fast that the systems give up and throw error lights/codes.
Sorry, that's just made up silliness.
J.A.W.
109
Just_a_fan wrote:
11 Jul 2020, 02:46
J.A.W. wrote:
11 Jul 2020, 00:19
Phil wrote:
08 Jul 2020, 11:59
"Silliness"? Ah, no..
Seems you've not thrashed a BMW car, in the last 20 years (esp' a big barge, or turbo) hard...
Whereas any 'superbike' of getting on for nearly twice that age,
didn't/wont, run out of brakes/tyres, on a tank of gas 'rinse/repeat',
'cept maybe, for a puncture, (& run-flat car tyres are pretty awful too).
Phil
66
Contact:
J.A.W. wrote:
11 Jul 2020, 00:19
Yes.
And guess what, i actually track my car too and have shared the track with bikes at times. What about you?
Ps: my car that i track doesnt have stability control and it doesnt know “limp mode” either. I've also tracked a modern BMW and it certainly doesn't crash or go into any protection mode if driven right.
#Team44 supporter
J.A.W.
109
Phil wrote:
11 Jul 2020, 09:11
J.A.W. wrote:
11 Jul 2020, 00:19
Yes.
Ps: my car that i track doesnt have stability control and it doesnt know “limp mode”. :lol:
Of course, but the other way around - riding a bike, ('til it was banned here, due to fatal crashes).
I have driven 'tests' which have caused the dreaded 'Las Vegas strip' on BMW's, & laughed when
production-racers fall foul of the same issues (going 'limp'), how about you?
Jolle
132
J.A.W. wrote:
11 Jul 2020, 08:29
Just_a_fan wrote:
11 Jul 2020, 02:46
J.A.W. wrote:
11 Jul 2020, 00:19
Lol, I did. Many of them. But not trashed but raced.
If you drive a modern BMW into limp mode, take a driving lesson or two, the car is telling you something (not a joke). Apparently you can’t brake without using ABS on every corner, so the servo is draining the battery or have so bad throttle control that you overheat the cat trough bad ignition timing.
Lern to drive.
J.A.W.
109
Jolle wrote:
11 Jul 2020, 09:46
J.A.W. wrote:
11 Jul 2020, 08:29
Just_a_fan wrote:
11 Jul 2020, 02:46
Lern to drive.
My Mercedes-Benz won't do it, under similar circumstances, but its a different breed of cat..
Andres125sx
J.A.W. wrote:
11 Jul 2020, 00:19
Are you comparing top supercars with top superbikes? Or top superbikes with normal sport cars?
Looks like you´re comparing apples to oranges, but this is not new from you
63l8qrrfy6
368
My M2 can blow any pocketbike out of the water
Big Tea
Mudflap wrote:
11 Jul 2020, 14:33
I can beat it on a 50cc as long as I chose the course :twisted:
Locked
